Mothers Clay Bar 2.0
#21
#22
My current plan is to test in a very small area first before I attempt the bolster. My main concern, not being a leather expert, is how the uncoated bare leather will absorb the dye compared to spraying the dye over a larger area consisting of bare leather and good factory colored leather. My worry is that the bare leather will absorb it and look a lot darker than the surrounding area making the entire repair look splotchy. The only way to know is to test. Maybe I am confusing the terms dye and paint. To me, dye soaks in and paint covers. We'll see.
#23
#25
Well, it turned out just ok but I also didn't expect a miracle. I will write up an article with closeups. I only did the bolster up to the dividing stitch. I wasn't going to do the whole side bolster but you have to as I figured out while blending.
Before with obvious wear.
This is after cleaning the leather, blow drying it and sanding it lightly with 500 grit paper. I did NOT use any leather filler cream but in retrospect it may have been a good idea. I just really don't know what I am doing just yet. Three coats of dye, dried with a hair dryer in between each and dabbed into cracks with a sponge brush. The dye is watery and clear-ish like I expected .... not paint. It looks a little funny in the pic but the lights in my garage were making weird shadows. I will buff it out tomorrow and see what that brings. I can always start over with the filler cream but I would have to order it. I just didn't want to use it because I wasn't sure about it sticking being under so much constant rubbing.
I think this will be acceptable to me until I get both seats totally redone. I just wasn't looking to spend over a grand just yet so this $30 is fine. I want to see how this wears and if the dye rubs off onto my clothing at all. I buffed a very small part of it with leather treatment and it didn't turn the cloth pink so that is a good sign. The worst I could have done is make it look worse than it was and it doesn't. lol
#26
#28
How well does the colour of the dye match the rest of the seat? Did you provide your interior colour code as well when ordering?
#29
It's kind of like that ten foot paint job on a car. It is MUCH less noticeable but you can see the areas that were previously bare leather with inspection. I could have gotten it to look better and I might still redo it at some point since I have plenty of dye left. I just wasn't that comfortable sanding leather and I didn't use any filler cream. This kind of stuff requires a few tries to get a feel for what you can do. It's scary prepping the surface with acetone and sandpaper. You realize there is NO turning back now.
The main thing I was concerned about was different textures of leather absorbing the dye differently and it did turn out to be the case. The bare areas were more "suede-ish" than the smoother red areas that were starting to wear. At this point I don't know what I'd do different aside from trying the filler cream and sanding it to an ultra smooth texture. Even then I would wonder if the hardened cream would absorb differently and look a tad darker.
I ordered code 89 which is correct for Honda red on the S2000. There is a definite difference between paint and this dye. It is a bit translucent as you can see on my test spray.
RolanTHUNDER (07-17-2018)
#30
