New Paint
Hello W&W whores!
I just had my fender, hood, and bumper repainted on Monday. Being W&W whore myself, I am dyining to clean my car. Is there any wait period ar any things I need to know ahead of time about cleaning new paint? It needs a wash and wax BAD. Thanks Guys :hello: |
I understand it that if the the paint was baked after being resprayed then no need to wait. If not the then leave for 6 weeks or so.
The best advice I can give is to tell you to ask your body shop how long you should wait before waxing the new paint. Likely they'll tell you somewhere between 30 and 90 days. In the meantime you can wash and polish your car as much as you want. To provide your new paint some protection put a "body shop safe" pure polish on it like Meguiar's #7. |
Mickey is correct, in that local shops can not cure the paint the same way as the factory. You can normally wash the car right away. Most shops will tell you to wait a min of 60 days. I know that if PPG paint was used they would like you to wait 90 days before waxing.
Originally Posted by 8800EZ,Sep 20 2006, 04:04 PM
i just got my S back last friday. You can wash it right away, however i was told to wait at least 30 days before i wax it.
Even though the paint is dry, the cure time or time for the paint to off-gass is normally 30-45 days. If you seal the paint it will dull or trap solvents and reduce the adhesive properties. so product that seals/protects should NOT (edit by wanabe) be used.
Originally Posted by hkspwrsche,Sep 20 2006, 04:28 PM
Even though the paint is dry, the cure time or time for the paint to off-gass is normally 30-45 days. If you seal the paint it will dull or trap solvents and reduce the adhesive properties. so product that seals/protects should be used.
yes, that is the technically correct answer with a typo so i will edit it- and will let hkspwrsche know.
Oopppsss... Hope no one went out and waxed some fresh paint! :D
