2006 LB 1 and 2 step Paint
So after a few posts pix and links i was contacted by a fellow member here to do a potential 1 step on the exterior paint, i quoted him blindly without looking at the car. After meeting him and looking at the car a little closer the car definitely required a 2 step. But after taking a couple measurements of the paint some areas wasnt healthy enough to compound the low Clear coat areas. Here are some pix of the car in the condition it arrived.
http://imageshack.com/scaled/medium/69/oamt.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/405/9k4x.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/189/wjga.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/9/bfcw.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/819/p95q.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/10/vfb9.jpgUploaded with ImageShack.com Heres a pic of the car with CarPro Tar X to remove any tar or previous LSP http://imageshack.com/a/img199/6081/etda.jpgUploaded with ImageShack.com And here are some pix after Using CarPro Iron X on the paint and wheels http://imageshack.com/scaled/medium/266/d7s0.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/692/tf5t.jpgUploaded with ImageShack.com So now to inspect the car when its dry http://imageshack.com/scaled/medium/14/i3nc.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/59/y836.jpgUploaded with ImageShack.com http://imageshack.com/scaled/medium/10/639w.jpgUploaded with ImageShack.com As you can see its pretty swirled up and noticed some deep scratches, heres a pic of the hood after i removed the swirls http://imageshack.com/scaled/medium/96/4lbb.jpgUploaded with ImageShack.com Heres an after pic of those scratches http://imageshack.com/scaled/medium/21/k8na.jpgUploaded with ImageShack.com |
Looks awesome man. Looks great.
Good work. Just curious though, did you use that small hand buffer on the entire car? If so is it swirled?
What products did you use on this project? |
Originally Posted by 318ap1
(Post 22754759)
Originally Posted by croftoncustoms
(Post 22754865)
What products did you use on this project? and my flex 3401 with the LC BP system i used menzerna fg400 Meguiars M101 Meguiars D300 Buff n Shine Foam Pads Meguiars MF cutting discs Sonax Perfect Finish 4/6 |
where u located?
Originally Posted by TimeScar
(Post 22786079)
where u located?
also curious, what area do you do work around
Originally Posted by 2leftshoes
(Post 22787410)
