Sparco Circuit 2 LF Halo with PCI mount. No hammer install.
If you could get a measurement of the PP and the Circuit 2 from the seat bottom (not the cushion as cushion density will effect how much it crushes down when seated) up to the bottom of the shoulder harness holes that would be awesome! I am interested to see how the 2 compare in terms of the height at which the harnesses come through the seat back. I would only ask you to do the measurment on the CIRCUIT 2 given I have PPs in my car, but i want to be sure the way you measure them is the same so it is an apples to apples comparison. HUGE THANKS IN ADVANCE!!!!
Thanks Freq!!!!! This is also super helpful to see there is height difference between the Circuit vs Circuit 2 as well. So from all of the photos posted by you guys it looks like we can surmise that the circuit is slightly taller than the Pole Position and the Circuit 2 is significantly taller than the Pole Position.
