How do you remove this bolt?
Old Apr 30, 2017 | 11:01 AM
415's Avatar
415
Default How do you remove this bolt?
Hi, how do you remove this bolt?
Old Apr 30, 2017 | 03:21 PM
Slowcrash_101's Avatar
That's strange, isn't a ball joint supposed to go there? There's no threads on that part of the knuckle, so I'm guessing you remove it the same way you take off the other ball joints.
Old Apr 30, 2017 | 04:55 PM
neurotic's Avatar
I presume that's from an aftermarket bumpsteer adjusting toe link.
Try something like this:
Old Apr 30, 2017 | 09:29 PM
Singh_snisen's Avatar
There is supposed to be a ball joint on it. U need to hammer it out and get a new arm.
Old May 1, 2017 | 01:02 AM
noodels's Avatar
Sharp tap with a hammer on the casting where your finger is pointing too.
or grind 2 flat spots and get a spanner on it.
Old May 1, 2017 | 06:57 AM
windhund116's Avatar
Maybe two nuts at lower end of threads. Tightened together? Then, ratchet the whole piece out?
Old May 1, 2017 | 01:54 PM
blueap2's Avatar
Do NOT hammer... the press shown above is the correct tool. Your local Autozone will loan the tool for free.
Old May 2, 2017 | 12:09 AM
415's Avatar
415
Thanks everyone, I will try using that tool.
SS Tony
Apr 30, 2016 01:34 PM
peters2000
Nov 29, 2009 07:19 AM
