Valve Springs, Retainers, Keepers - AP2 or Aftermarket non-Ti?
Old Dec 9, 2020 | 10:52 PM
Bullwings's Avatar
Default Valve Springs, Retainers, Keepers - AP2 or Aftermarket non-Ti?
It's a beaten to death topic with all sorts of varying opinions. I'm looking for feedback from people who track their cars. I have about 80-100 track days on my car, and it seems that my SuperTech Ti kit is starting to go bad.
I need to replace them, but i'm not sure if I should go back to AP2 OEM or an afterket non-Ti kit with dual valve springs. I want some mechanical over-rev protection in case of a money shift. Power is pretty basic and will remain that way - exhaust, test pipe, OEM airbox with snorkel, OEM tune.
Latest oil report below:
Old Dec 10, 2020 | 10:35 PM
djsilverjohnson's Avatar
The OEM AP2 stuff lasts the life of the car in the AP2 so why wouldn't it do the same in an AP1? I bought an AP1 with 45k, changed them at 50k. It's got 99k now and it's all Autox, track days, and driving to/from events. Hammer the rev limiter without fear and never look back. Aftermarket parts may have a performance advantage in some areas, but very few can beat OEM for reliability and service life.
Old Dec 12, 2020 | 07:38 AM
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
For an AP1:
-OEM ap1 springs
-oem ap2 retainers and keepers
ALL aftermarket head components are garbage (for the S2000 at least)
Old Dec 12, 2020 | 10:40 AM
Bullwings's Avatar
Yeah. I figured as much. I know the aftermarket stuff isn't designed for longevity. I'll take solace in believing that my current kit has saved me from a few money shift zings over the years.
I was considering the SPRK-H1021D from supertech, which i believe is steel, but i'll just go OEM AP2 and call it a day.
Old Dec 12, 2020 | 02:21 PM
nipponS2000's Avatar
What about oem ap2 retainers and keepers along with toda springs for revving the ap1 9300-9400?
Old Dec 13, 2020 | 04:12 AM
Top Answer: 1
What problem are you trying to rectify?
Old Dec 13, 2020 | 12:59 PM
Bullwings's Avatar
I essentially want to survive revving to 10K on a missed down shift/upshift. I'm not the best driver and have definitely done a couple of 2-1 upshifts (missed 3) while heavily laterally loaded.
In any case, I already ordered a full set of AP2. Assuming no future miss-shifts, I wonder how long this motor will continue going. I'll be happy with another 80 track days on the motor. I intend to keep the motor as is - OEM tune, snorkel on OEM airbox, 63mm test-pipe, and exhaust.
Old Dec 14, 2020 | 04:16 AM
Top Answer: 1
Raising the valve spring pressure is not necessary and will only increase noise, and wear.
AP2 retainers and keepers and thats it. Safe to 10k in an over-rev.
Find a way to not mis shift. Number one cause is holding the shifter tight (death gripping)
Relax, drive fast, shift slow. Upgrade your skills instead of downgrading the engine.
Old Dec 14, 2020 | 05:39 AM
roel03's Avatar
I used to have a big problem with miss-shifting a few years ago. I went back to the OEM shift knob, instead of countersunk Moddiction Anvil 2, and haven't miss-shifted yet. The throw on the S2000 is so short that any shorter and the risk of miss-shifting gets considerably higher.
The worst cases are 2-3, 3-4, and 5-4. Each has a different way of positioning your hand in order to avoid miss-shifting on this car, which I'm sure you already know about.
Old Dec 14, 2020 | 06:10 AM
Bullwings's Avatar
Yeah. I've since switched to an under-hand grip (for 2-3 and 4-5) using a light-weight delrin shift "lever" raised 2" instead of a knob. It's rectified my issues. Essentially, learn to shift better...
Eggrolls4lunch
Feb 7, 2017 02:29 PM
AK4766
May 23, 2016 05:32 PM
Richvow
May 23, 2016 11:40 AM
