AC Delco Syncromesh Manual Transmission Fluid (Friction Modified)
Part 10-4014
88900399
Synchromesh Manual Transmission Fluid (Friction Modified)
Contains a semi-synthetic lubricant compatible for use in NV 1500 transmissions
Reduces transmission component wear
Here is a link to get part numbers for AC Delco lubricants:
http://www.acdelco.com/html/pi_vehcare_lub.htm
88900399
If it lasts 7K that will be fine with me. The non-FM synchromesh lasted ~3-4K.
RR, is there any difference between the AC Delco fuid you listed and the GM SYNCH FM fluid you can get from the GN dealer? Is it merely repackaged?
Just curious...
Just curious...
