The Windy City - Off Topic A place to relax and unwind. Off topic section of the UMW.
What I did to my non-S2000 part deux
Old 09-03-2014, 12:34 PM
ruexp67's Avatar
Default What I did to my non-S2000 part deux
Old 09-03-2014, 12:42 PM
Site Moderator
sam_spider's Avatar
Received 2,587 Likes on 1,903 Posts
Since Pete is a
Originally Posted by ruexp67
Gas left in a tank will eventually evaporate leaving behind impurities and things that don't evaporate. It usually takes at least 3 years before you start to see the sludge/cake in the bottom of the tank.
Fuel spilled on the ground, will evaporate MUCH faster of course.
It's possible it leaked to below where the leak is. Try rocking the car to get more to spill out. or top it off with a SPLASH or two of fuel.
Originally Posted by BlueBarchetta
And the fuel could have discolored the floor, and that's what you're seeing
I thought it took longer to evaporate, I noticed it in the morning after putting the car away the night before. No moisture at all, just the outline of a puddle and a slight discoloration. Definitely a smell of fuel in the garage though. The size of the puddle is pretty big, like 4'x2' and right under the right rear side of the car.
I guess I need to jack the car up and take a peek.
That's a LOT of fuel. It could evaporate that fast. It's more like alcohol than water for evaporation.
That's the problem though, I'm not certain if the puddle thing was there before or not. I'm hoping to get home early enough this evening to put it up on jack stands and take a peek.
Old 09-03-2014, 04:19 PM
Site Moderator
sam_spider's Avatar
It's fuel. I found the leak this evening. Going to be a royal pita to replace the part.
Awesome.
Old 09-04-2014, 04:09 AM
chazzguitar's Avatar
well, glad you found it -- better to have an answer than a phantom fuel problem on your hands.
Old 09-04-2014, 05:14 AM
Site Moderator
sam_spider's Avatar
Definitely. It was pretty obvious once I put the car up on jack stands.
I've found the part I need, but their site is having issues so I can't order it. Grrr.
Old 09-04-2014, 06:22 AM
ruexp67's Avatar
I had a fuel leak into the trunk (all over the battery, which was awesome by itself) of my Alfa. The padding and carpet were saturated and the smell of fuel lasted for MONTHS. It was pretty aweful.
Old 09-04-2014, 06:27 AM
manufan's Avatar
I had a fuel leak in the Jetta. In the rocker panel. Oh, and a rivot in the wiring harness...but you all knew that
Old 09-04-2014, 06:34 AM
Site Moderator
sam_spider's Avatar
That had to suck, getting that fuel smell off of fabric is a major pita.
I ended up ordering a piece of hose online, I was really hoping I could find something locally but nada so far.
Old 09-04-2014, 05:20 PM
Site Moderator
sam_spider's Avatar
Think I fixed it but won't know for sure until in the morning.
Pics of the old hose and new hose installed. It took forever for the gas to drain as there isn't a drain plug, so I cleaned and polished the original clamps. I was bored
Attached Thumbnails What I did to my non-S2000 part deux-image.jpg   What I did to my non-S2000 part deux-image.jpg   What I did to my non-S2000 part deux-image.jpg   What I did to my non-S2000 part deux-image.jpg
Old 09-05-2014, 05:02 AM
Site Moderator
sam_spider's Avatar
Looks like I fixed it
Quick Reply: What I did to my non-S2000 part deux
