flanders NFR AP1 build
Old 03-10-2016, 11:41 PM
flanders's Avatar
Default flanders NFR AP1 build
Hi and welcome everybody.
I got this car late summer of 2013 and I've been constantly doing some mods and improvements since then.
I've got a long a build thread on another local forum but I thought it would be nice to have it documented here as well.
So from the beginning
Newly bought on a lovely Swedish summer evening.
There were some mods done by previous owner and one of the bad ones was the intake
So I got me a CT intake instead
It felt like it did pretty good gains and my logs seemed to agree
Steering wheel was a really worn out Momo so that was also changed to a 350mm Personal neo grinta.
It already had a Swedish made SnapOff hub/quick connect and that obviously stayed.
Another pic with a glimpse of the new carpets
Also changed some of the bulbs for LED.
Before and after
Some various parts from the US, did the shifter regrease and changed out my broken white plastic tab for the gaiter.
And mounted this nice little tray.
One of the most important mods done was depinning the speed signal for the top up/down.
The top up/down still need the e-brake engaged at one click work so feels pretty safe.
Old 03-11-2016, 12:11 AM
flanders's Avatar
Nice big package arrived from Evasive
With some exhaust parts
Invidia test pipe with cel fix, looks like it actually is a mini catalyst inside.
This was a bit disappointing but I guess not a big deal, I ended up just pulling it off completely and put it on the wall in my garage.
Pulled out 3,2kg of air pump crap
and replaced it with this resistor
A bit more room in there now
In the engine compartment I made a block off plate for the valve.
Used the gasket as template but I made it a bit too exact on my first try lol, end result is in the bottom.
Installed
I got a horn over from the CT intake install and swapped that with the ugly looking one in the front.
Painted the AC drier bracket and found a nice fitting plastic sleeve that slid right over it.
Looks a bit more discrete in there now
Live Fast (04-07-2020)
Old 03-11-2016, 12:21 AM
bMa912's Avatar
Looking good so far. Good job!
In for updates
Old 03-11-2016, 12:26 AM
flanders's Avatar
Got some stuff to keep engine a bit cooler.
Dei wrap
Hondata intake manifold gasket
Before install I did some thermal imaging to see how much difference it might make.
This was done after 10min idle with hood closed, temps are not 100% since different surfaces and colors have different emission values.
I put some black electrical tape on the manifold to make the reading more accurate.
Kind of hard to do that on the the header and those values are probably way off.
Temps are in Celsius.
Old 03-11-2016, 12:44 AM
flanders's Avatar
Removing the intake manifold was a real pain but I found this guide that helped a lot Installing an Intake Manifold Insulator/Spacer
Time to clean up the throttle body
Put some smaller countersunk screws for a tiny bit of better flow.
OEM on the left
Pulled out my Toda header as well
Stretch, pull and wrap until your hands are numb
A lot more work than I thought but the result looks pretty nice
Cleaned out intake manifold and the "upgraded" TB
Old coolant fluid out
New coolant and some deionized water for flushing
Engine block coolant drain, got pretty wet under there when that was removed
After some very smoky (header wrap) bleeding I think I got most of the air out from the coolant system
Old 03-11-2016, 12:50 AM
flanders's Avatar
Result were about 20 degrees C (33F) lower temps even though I let it idle for 10 more minutes
Before 54C/130F
After 36C/97F
Header looked really weird in the camera so no results there.
Old 03-11-2016, 01:12 AM
flanders's Avatar
Stock exhaust off
Also got this single exhaust cap from HeeltoeAuto.
Pic from first try with the included tape was a complete fail, it almost fell off on it's own.
With some new and better tape and some help it went on and stayed on
This bracket sits behind the license frame plate and pulls it to the bumper, really helped to release it so that the top edge of the cap could slide under.
It looked like shit so it was completely removed, sandblasted and painted.
Made some new exhaust mount rubbers
Tail pipe didn't sit very well on first try
So I made this rubber mount
and installed it like this
I a bit close up top but looking much better
Two more shots
Old 03-11-2016, 01:36 AM
jonner's Avatar
Keep up the good work.....
Old 03-11-2016, 01:47 AM
flanders's Avatar
Thanks, there is lots more to come
While working under the car I decided I really had to do something about the rear cross beam bar that the previous owner had installed.
This is what it looked like, I call it the blood stick.
I made this one first but it looked a bit weak.
So with some help from my sock monkey this was made instead
60x10mm is hopefully enough
Installed
Old 03-11-2016, 02:03 AM
flanders's Avatar
Next I got a Greddy Emanage Ultimate from a fellow s2ki member.
It came with a wideband which I installed in an available bung on my Toda header
Put the electronic box for the o2 inside here
The cables were of course a bit to short so had them lengthened
The PnP harness to the stock ecu was a super tight fit but with the ecu turned 90 degrees it was possible get it all fitted behind the stock plastic panel
I put the calibration button and blinky led for the wideband here
and the AFR display
At first I put the Greddy box behind the seat
it limited sliding the seat all back though so I moved it over here instead
Quick Reply: flanders NFR AP1 build
