What's the best diff and trans oil and weight ??
New to this site, i have an 04 s2000. I want to know what are the best differential oil and weight for it .. and also the trans oil and weight, what do you guys recommend? Thanks in advance !
Honda MTF for the transmission, 1.6qts is the recommended amount. And for the diff I live in a warm climate so I personally went with Amsoil 75w-140, but 75w-110 will serve you great, 0.75qts for the differential.
amsoil manual trans fluid will last a lot longer than the honda mtf.
90w in the diff and you'll be good to go. i run 190w amsoil for my diff for extra protection since i've had some damage from my pinion nut getting loose.
