Trying to figure whats wrong, help needed!
Got a ap1 boosted, and im trying to figure if head gasket, valve seal, or rings went out before i make any major plans on building it! Dont want to build it if not necessary! Was pushing the car to about 8k rpm than suddenly big cloud of smoke 'oil burning' had misfire turned engine off and tried turning it on again and engine was really hard to start up! Only cyclinder 1 had oil on the plug all the rest were fine! Now im just trying to figure out whats wrong seeing if i should just do valve seal and hope its that or is there any way to test if its rings or hg? Took of some of my ic pipe and no oil in it, but my waste gate had oil coming out of it.
Yep, and doubt its valve seal. They typically don't just suddenly go out in this scenario. I'm guessing a ring land let go. Which means your cylinder is scored and either sleeving the motor or replacement is your options moving forward. But get a scope and inspect the bore, or if you don't have access to one do the comp and leakdown test.
damn that sucks lol...and also my car smokes from time to time from driving and coming to dead stop and idle and sometimes on start up, not sure if thatll make a difference in knowin but ill probably just do a leakdown test later :'( and one question if it was a ring wouldnt oil be in my intercooler piping? Just a thought
What I'm not understanding is, oil in wastegate so pretty much i got oil in my turbo mani. Wouldnt that oil get sucked into turbo blowing it back into pipe? Maybe im just not making any sense. Or im just over thinking atm
Maybe a seal in your turbo?
Ahhh, I think you have bigger issues. But yeah, hope the bearing in the turbo didnt get washed as well. Looking at the mud soup and what looks like water droplets mixed in, my first though is blown HG. But im not as privy to what E85 looks like mixed in with engine oil. What im seeing and hearing so far though, you have engine damage, with best case scenario being a HG, and worst your cyl #1 is down and possibly damage to your turbo as well. It could just be blow by from your cylinder thats down though, and turbo is ok. You wont really know until you clean it up and start examining things.
