Using reverse
Losing reverse
Hi,
I have lost reverse gear on my last two track days. After I get done with my forst session, I can't push the shifter down to get into reverse. When I'm done wih the track day and given the car 1-2 hr to cool, I can push the shifter down. It is just a problem to park in the paddock sometime.
Clutch and tranny fluid are fresh. I used ATE for clutch.
any advice/thoughts?
Same issue
I have the same issue between sessions on track. I put clutch in and reverse will grind going in as if clutch not in all the way. Not other gear does that, I have no issues with 1 or 2 in the paddock, but when it's time for reverse forget about it. Clutch fluid less than 1000 miles.
