intake and exhausts for 2007 stock s2000
Old 06-24-2017, 10:10 AM
rfcdesilva's Avatar
Default intake and exhausts for 2007 stock s2000
so far im thinking about the K&N57 series (intake)and T1R 70R-EM Sparrow (exhaust)
please let me know if there are anything other than this i can check out that you recommend in your own experience
thank you
Old 06-24-2017, 11:09 AM
WVCR-V's Avatar
Do you have a flashpro tune yet? If not I would put that money on a Berk 63.5mm high flow cat and a flashpro+ Gernby tune.
Old 06-25-2017, 05:12 AM
Chuck S's Avatar
Received 1,133 Likes on 996 Posts
Just adding bolt-ons will not increase the car's performance more than the OEM ECU can adjust for. The FIPK will add a couple. Don't know that exhaust other than it's $1,400 which if spent as recommended above will have some impressive gains for you.
A Gernby FlashPro tune will amaze you with the mid range power. VTEC power comes on at 3600, not 6000 rpm. Requires a high flow cat (Berk 63.5mm personally recommended). I have the FIPK and a Tamabe Medalion Touring dual exhaust and am very happy. First with the tune and secondly with the exhaust as it's more aggressive than OEM but not annoying to me (or my neighbors).
This is all DIY with simple tools and maybe a buddy to help remove the stock exhaust. Find the Mighty Car Mods episode where they fit the (horrible) Invidia Q300 exhaust to their S2000. Fitting the Berk high flow cat is even easier with the entire exhaust off the car. The OEM is one piece and heavy. The aftermarket exhausts are typically in 4 pieces for shipping purposes and easy to install. The FIPK intake will take longer to install.
-- Chuck
Old 06-25-2017, 06:51 AM
osu1978's Avatar
Whatever you buy OP, just make sure to pair it with a HFC/Test pipe and flashpro tune. Most of gains are going to be from the tune.
Old 06-25-2017, 04:02 PM
WVCR-V's Avatar
I should also add that the flashpro tune with the Berk HFC will improve the sound in the midrange due to the earlier Vtech engagment. So even with the stock exhaust it sounds more agressive than stock. I would like to do the Tanabe touring exhaust next. I bet it really sounds good with that.
06s2kid
12-07-2016 07:50 AM
cbezzy01
03-12-2016 01:52 PM
Sogno
11-20-2015 03:17 AM
bluerennfahrer
09-19-2013 10:31 AM
fustyd
12-15-2007 09:04 PM
Quick Reply: intake and exhausts for 2007 stock s2000
