How large of a tweeter can we fit in the door?
Trying to build an active front stage with an Sb acoustics sb17 mid and NVX's version of the sb29 tweeter and wanted to keep the interior looking stock
Will the stock location be large enough, in both diameter and depth, to house this tweeter?
size of the tweeter:
2.32" / 59.07
2.27" / 57.67 mm cutout dia
1.03" / 26.1 mm mount depth
pics for reference
2.32" / 59.07
pics for reference
if they're too large, I'm guessing my only option (to make these work) would be to order a spare set of OEM tweeter grills, cut them up and fabric them over
I'm guessing this will also mean removing the oem hardware behind the grill and doing some sort of custom metal work to keep the tweeter held in place
like this:
like this:
Site Moderator
You're definitely gonna have to do some work to get those to fit in the stock location, those are massive.
I think you'd be better off building a pod to place at the base of the A pillar.
Though I am thinking now to make this a longer-term project and try to fab something up on or near the A-pillar
Good luck. Tell us how it turns out.
I'm running tweeters from Alpine SPS-610 kit, in door. Definite improvement over OEM. Must install sound deadening mats (I used Dynamat) to reduce buzzing at volume.
Also, Alpine KU-445A amp under dash.
I did the Arc Audio variant of the SB Acoustics tweeter. The larger NVX version was too big to fit in the OEM location outside of the door. I just fiberglassed these in using the supplied cup for an OEM like look. I used the poly SB17's in the doors (https://www.madisoundspeakerstore.co...y-cone-woofer/) with homemade mdf spacers.
Clean job, on those crossovers. Love those air-core chokes. You do home systems, too?
I have a couple of JBL studio monitors which need restoration. Reconing the speakers, plus R&R the crossovers. I'll get around to them, one day.
