KS:FS FUllblown motorsports TC kit Gtx3582 gen2
This kit and turbo was bought NEW MAR of this year. 5k miles on kit and turbo. Installed, tuned, drove across country and then taken off. As far as the kit n turbo goes. Its dead reliable, Im just looking for something with a different manner an attitude.
Firstly: things you will need (concerning kit an turbo) During removal 1 nut became seized attaching turbo to manifold. I sheared it off, so its down to three.
The lower cold side charge pipe came from FBM with a very odd and ultimately inneffective bend to it. Had to cut it and add a coupling. Worked without fail after with no pipe blow outs.
The down pipe comes with no attachment or "flange" so you can add which ever you want or have. Currently has a 3" vband welded to it.
The cold side charge pipe from throttle bodie has a ap2 air intake temperature sensor adapter bung welded to it. If your not ap2 a simple cut of round stock will seal it up using the adapter as designed, a separate boost source port was added right by it so you dont have to run a extra line from pcv. . Its also welded to the bottom and out of eye sight. GTX3582 gen2 turbo in perfect condition.
Everything that comes with the kit is included. In addition im also including:
Ap2 Injector Dynamics 1000cc Injectors
plug & play injector clips
an ap1 fuel rail machined for ap2 injectors (if your ap1) (included bushings for rail posts for height) they came with return fuel conversion when I installed. I believe the heights of the injectors are different so im including them.
A slightly used but in working condition when removed name brand Walbro 255lph fuel pump (just pump) a quick search of install kits came right up
Canton Motorsports baffled oil pan
SoS 4bar ap2 map sensor
innovative 95a billet engine mounts.
$4275 shipped in lower 48
Thanks for the look.
I CAN send a bunch of pics but cant upload them right now. If interested please pm me and i will give you contact to see everything. OR please see my fluidampr FS thread. I tried just changing it to a garage sale title but it didnt change (wanted to include kit FS in title soo here it is. Pics in other thread. Ill answer any questions you have.
Bump for BF sale. Price reduced to 3800 as whole with everything listed.
Will part turbo but have to buy As whole.
$1000 included exhaust housing, restrictor, oil outlet, water fittings. Youll pay shipping for just turbo tho.
Nfinitecc
Forced Induction For Sale
12-14-2018 12:25 PM
Nfinitecc
Member S2000 Classifieds and For Sale
13
12-05-2018 08:17 AM
CRVRX
03-09-2015 02:26 PM
