No start after engine swap
Swapped my original motor back in after spinning a rod bearing in my F24.
Car cranks and fires/runs briefly for a half second sometimes before dying.
I've verified the 3 ground (back of cylinder head, 2 near AC.
Checked all fuses, none are blown.
Swapped ignition coils between my two S2000, swapped injectors between them too.
No CEL are on.
Timing is correct
Does anyone know if having no airbags/stock seat belts connected prevents startup?
No CEL are on.
Timing is correct
i can see fire poof out the throttle body (have no intake on) when i crank sometimes so i know its getting fuel and spark
fuel rail was also full of fuel when i swapped injectors
pulled the plugs and they were good, normal electrode, color was blackish
Problem I had was one rear cam sensor was in wrong way as the tab had broken
i actually just swapped the two sensors on the valve cover just in case but that didnt make a difference
on the cover,<one for each cam>
