Fuse Tap - Under Dash - what to use for Constant power ?
I am trying to install a Blackvue camera w a magic pro box (I want to use parking mode). I am trying to use fuse taps to tap into the 9 (accessory power) for accessory wire. I want to use the 23 (brake lights) for constant power\battery wire. However the fuse taps are too big and won't fit right next to each other (since 9 and 23 are in the same row).
Can anyone help me figure out from the fuse diagram below, what other fuse besides 23 can I use for constant on power source?
NOTE: The magic pro would only work with 12V setting and not 12.5V (minimum volt jumper). Is 12V for S2000 stock batter (brand new) the right setting. It won't turn on with 12.5V.
Check out this thread: https://www.s2ki.com/forums/s2000-el...use-box-97374/
You do not need to tap a fuse. There are spade terminals in the fuse box that will provide BATT, IGN, and Lights power.
The magic pro actually has a few voltage options so once it dips below the voltage chosen (think 11.2v is lowest), it'll shut off the camera.
Yeah if you don't mind. Thats exactly what I am trying to find out i.e what fuses your are tapping into for accerory and battery (constant). again I want to use 9 23 but can't chose both together.
A spade terminal is a pretty simple thing and easy to obtain. You would just crimp that onto the wire and then plug it into the fusebox terminal. You also mentioned you were having issues with the add-a-fuse not fitting or running into things. This method would not have that problem.
Either way should work though.
As for the trigger voltage, you should see at least 12 Volts from the battery when the car is off. If you are seeing less it is likely due to a wiring issue. That is another reason to use the spade terminal. The wiring for the fuse you tap may not been large enough gauge to prevent voltage drop.
kasher_khan (01-22-2018)
By tapping an existing fuse you are scabbing on a circuit for another accessory. Those terminals are there specifically for this type of situation (adding an additional accessory). To protect the wire you should include an in-line fuse as well.
for_my_s2k
07-27-2013 06:09 PM
fireball
05-08-2004 06:48 PM
