Possible seat theft deterrent
While working on my car I pulled the seats and saw through to the floor after removing the (10x20) bolt to the rear and inside of the seat frame. So I crawled under the car and found the area. Only one of the four bolts holding the seat in is visible. Went to the local hardware store and purchased a 10.9 (10x25) bolt, washer and nut. The intent was to use the nut as a “lock” nut. I think a (10x30) bolt might be better because you are unable to get full threads on the shorter bolt.
Factory seat nut
Installed locknut
Factory seat nut
Installed locknut
Seems like a clever, and reasonable solution!
It may have an unintended advantage. I imagine smetimes a thief might get pissed at finding theft deterrent bolts, and do something like slash your seats as retribution. But with this solution it just seems like a rusted frozen bolt, so maybe they don't realize its a theft deterrent.
Except! That one bolt is all shiney and new, and different style than the rest. A clever thief might instantly realize what you did, and thwart your efforts. If you could find an oem bolt from some other part of the car, that was long enough for this trick, it might look the part enough to not be a giveaway.
If anyone orders one and finds the ideal length, please post link to bolt & jamb nut to order.
ROD
How are they going to get to the seat frames if they can't get the bolts out? Do you think a thief is going to stick around and try to rip out the seats by hand or crowbar making all kings of noise? I can get my seats covered for under $600 a seat. In fack, I'm going to get my seats covered in the next 2 or 3 weeks. Going to have them cut out around 1" of foam out of the seat bottom and put 1 1/2" of memory foam in it's place with the center of the seat bottom and seat back cloth so it will be warmer in the winter and cooler in the summer. These seats get hot when it's 90F or more outside and we can get temps that high in 8 or more months where we drive.
ROD
ROD
How are they going to get to the seat frames if they can't get the bolts out? Do you think a thief is going to stick around and try to rip out the seats by hand or crowbar making all kings of noise? I can get my seats covered for under $600 a seat. In fack, I'm going to get my seats covered in the next 2 or 3 weeks. Going to have them cut out around 1" of foam out of the seat bottom and put 1 1/2" of memory foam in it's place with the center of the seat bottom and seat back will be cloth so it will be warmer in the winter and cooler in the summer. These seats get hot when it's 90F or more outside and we can get temps that high in 8 or more months where we drive.
ROD
ROD
