Turbo s2k braided lines
Hi guys, I need to order my fuel lines. What would be best? 8AN feed/ 6AN return OR 10AN feed/8AN return? Is bigger better or can you go to big? I just don't want to do have any limitations down the line and need to do them again to be honest? The turbo I'm running is a (gen2 gtx 3582r) and will be installing the sos twin pump surge tank.
Thanks for the help
Thanks for the help
I went with -10/-8 but I'm on E85 and will be over 1k whp.
This is brilliant thank's guys, so really up to 900-1000 hp -8 is fine but -10 for 1000+hp
Does anyone know if there's a downside to having oversized lines? I was thinking more fuel not being used going back to the tank constantly
being heated up
being heated up
Oh I see, the staged pumps are a good point, but as the -10 lines will hold a larger amount of fuel even with staged pumps there will still be more fuel circulating to the engine and back to the tank? Or have I got this wrong? I just can't help but think there must be a good reason people go for the -8.
Oh is it dependant of what fuel your using? Is that rite you need more E85 for the same power level?
