S2000 Strong Fuel Vapor Smell in Hot Weather
Hello,
I have a 2005 S2000. With the weather hot in AZ, when the car is parked outside for extended period of time, after driving for 10 miles or so, and parking, I get an intense gas vapor smell, right around the left rear wheel well.
The evap canister was changed (as the car is not driven often) as was the fuel filler cap. (No codes are thrown, no CEL). I keep speculating what might be the cause: EVAP bypass solenoid valve, EVAP canister vent shut valve, EVAP two way valve, a hairline fracture is the lines...? This happens only in very hot weather. If you have had a similar issue that you managed to solve, I would much appreciate any suggestions.
Many thanks -JR
PS. Had it checked at a dealer to no avail.
Many thanks -JR
bsconz
09-02-2012 08:11 PM
