Aston Martin Speedline 10 Spoke Wheels
Looks like these would fit our cars quite well
https://tampa.craigslist.org/hil/pts...619544320.html
they are front 8.5Jx18 - 5x114.3 - Offset 50 and rear 9.5x18 - 5x114.3 - Offset 62.5 Couldn't find the exact weight.
I found the specs on this UK ebay listing.
https://www.ebay.co.uk/itm/Aston-Mar...sAAOSwft9au~u9
Well who would have thought an Aston wheel fitting. Those look a lot like the ap2 v1.
Bore difference can be addressed by running a non hub centric 5mm spacer. And with those offsets your good, just roll the fenders.
If the 18" might fit how about a set of 19" A/M wheels? With installed tires you would need a good roll job.
These have some curb rash but they have the same offset, 50.3mm for the front(8 1/2" wide) and 62.5mm for the rear(9 1/2" wide)
https://www.ebay.com/itm/Aston-Marti...245?rmvSB=true
Would like to know how much they weigh, but if they could fit a S with little to no work it could open up our cars for other wheels that should be well made.
ROD
ROD
A 19" wheel would require the smallest sidewall.
And look awful.
And look awful.
