Gravity brake bleed - crap?
Old 07-16-2018, 05:57 AM
Riknos's Avatar
Default Gravity brake bleed - crap?
Hi All,
I changed my brake fluid last week and decided to use the 'gravity' method that I read on here so much about and everyone raves on about... and now my brakes are spongy and crap?
What gives? I used almost a whole litre of brake fluid, followed the correct order, but still spongy.
Did some reading on here and found the "leave brake pedal depressed over night" tip - so will try that and see if it works.
Anyone had good luck with pressure bleeders on the s2k?
Old 07-16-2018, 06:53 AM
engifineer's Avatar
Received 1,193 Likes on 926 Posts
I have never used the gravity method on any car, so I cant speak to it. Did not want to wait a day to do a simple brake bleed. Have always used the two person or a pressure bleeder on all my cars.
Old 07-16-2018, 07:08 AM
S2GARAGENYC's Avatar
I always gravity bleed my S2000, and I have never had a better feeling brake pedal on any car.
Old 07-16-2018, 07:13 AM
Billman250's Avatar
Received 1,253 Likes on 763 Posts
Gravity bleed will take 20 minutes on a car with warmed up brakes.
If the pedal is now spongy, the MC fluid level got low enough to pull in air.
Old 07-16-2018, 07:40 AM
jaor.s2k's Avatar
^^I agree with Billman.
I use the gravity bleed method and works perfectly.
Old 07-16-2018, 08:26 AM
Silkyjohnson's Avatar
This
While time consuming(I had done mine cold while on jack stands over the winter doing a bunch of other things), it was totally worth it. Best feeling brake pedal of any car Ive had
Old 07-16-2018, 09:03 AM
freq's Avatar
Silly comment.
Doesn't take "a day". Can be done while doing other work on the car. Doesn't take a second person which isn't always available and doubles your man hours.
Old 07-16-2018, 09:49 AM
engifineer's Avatar
Originally Posted by freq
Silly comment.
It takes longer than doing it without pressure on the line, so its not "silly". I was not being literal so obviously it does not take all day.
I use a pressure bleeder, no second person needed, comes out perfect every time and I dont accidentally walk away and let the reservoir get too low and pull air in Pressure bleeder cost me less than $100 and I have used it on all my cars.
Old 07-16-2018, 10:09 AM
kukudm's Avatar
I'm just wondering if gravity method will work for other cars that are using DOT3/DOT4 fluid?
Old 07-16-2018, 10:50 AM
Riknos's Avatar
perhaps I should have warmed the brakes up then?
fluid level didn’t get any lower than 3/4 or 4/5 full
in the MC. I was watching it like a hawk and constantly topping it up!
Is it literally just a plain open ended hose used for
gravity bleed and not one with a 1 way valve or anything in it?
Quick Reply: Gravity brake bleed - crap?
