Installed a Topsonline Brand Canvas Top.
So, I recently noticed that Topsonline.com began to offer their own brand of tops. I was also pretty badly in need of one and wanted to switch to Canvas anyway.
https://www.s2ki.com/forums/s2000-bo...t-top-1186218/
The Topsonline brand is about $190 cheaper than Robbins, but is made of the same material. This was my first soft-top install, and as most people recommend, I set aside a weekend to do the job. It took me about 10 hours, working slow and reviewing the video from Topsonline. Only a few things differed from OEM:
- 2 stud holes in the back that were not marked in the correct place. I put the top on the studs to either side and punched a hole in the correct place.
- The passenger side tab that fits under the weatherstrip at the back of the door didn't have a hole marked. I put it in place and punched my own hole.
- The velcro-ed band that goes from the 4th bow to the 3rd is pretty tight. I could not get the top closed at first, so I un-ddid the pinch and gave it some slack by overlapping less of the velcro. It is still tight as you can see in the photos, I may get some 2-sided velcro to add another centimeter of slack if it doesn't stretch on its own.
Enhh. The space between the 3rd and 4th bows is pretty slack now, and the rear window area is still overly tight. I am not sure that it was worth saving the money over a Robbins top.
I'm about to order a new top for my MY00 with glass and the topsonline brand certainly is temping to save so much money... but my current top from previous owner was a replacement top and aside from the glass separating... it's in perfect condition.
I don't know what brand my top is but I am leaning back to the robbins brand after seeing your opinions after only a couple months. But if the fabric is the same brand... i wonder why performance installed would be different.
what year is your car ?
