Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
1 Year in car storage, 1 more to go - Should I interupt?
Old 10-17-2018, 10:54 AM
NewFormula's Avatar
Default 1 Year in car storage, 1 more to go - Should I interupt?
Hi guys,
My S2000 has about 17,000 km on it.
Last October I put in in storage. I took all the recommended storage steps except for changing the oil. I had Amsoil in there from the beginning of that season (maybe 2000 km driven).
I haven’t touched the car since last October, it’s been under the car cover with the windows open a crack, battery disconnected, stabile added, handbrake disengaged, tires full pressure, etc.
I need to keep it this was until spring.
Should I interrupt the storage to give it a drive this month just to lube all the moving parts or would it be okay to leave it as is until next spring?
Thanks all!
Old 10-17-2018, 01:21 PM
Chuck S's Avatar
Some reason to post this again? Didn't like the responses you got responses the first time?
-- Chuck
Old 10-17-2018, 01:57 PM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
It wont know the difference, so just leave it as is.
Old 10-17-2018, 02:17 PM
NewFormula's Avatar
-- Chuck
No, I did not to tell you the truth. I solely got the manual recited to me last I checked that thread. Figured we'd know winters (storage) better here. Thanks for calling it out though
Old 10-17-2018, 02:22 PM
NewFormula's Avatar
Thanks that relieves a little stress for me. I just don't have the time for that now. Can't wait until next season!
Old 10-17-2018, 02:45 PM
clubhopper's Avatar
Just leave it for now.
i would do the following before you drive it again next year:
Prime the oil.
pull the coil plug connectors off, pull the fuel injector connectors off and crank it for about 10secs to lube the car again before driving.
plug everything back and start the car for your drive
Old 10-17-2018, 03:12 PM
noodels's Avatar
^^ What he said
Old 10-17-2018, 07:51 PM
zeroptzero's Avatar
I would avoid any unnecessary dry starts if possible. But since it is going on 2 years I would probably rotate the motor/crank by hand say 180 degrees just to get the springs compressed in a different spot and cam lobes touching different areas. Probably not a big deal but something I would consider for a 2 year storage time period.
Old 10-17-2018, 09:36 PM
Lucidify's Avatar
Smile
My unnecessary ass pulled the valve cover and pulled the plugs, dripped some oil in my cylinders, on my valve train and rotated it a couple times .
Old 10-18-2018, 01:08 AM
zeroptzero's Avatar
^ Sounds good
NewFormula
10-20-2018 02:25 AM
pmk229
12-03-2014 03:43 PM
S2KPC
10-28-2009 08:02 PM
blackfx35
12-20-2005 11:40 AM
RazorV3
05-25-2004 02:15 PM
Quick Reply: 1 Year in car storage, 1 more to go - Should I interupt?
