new engine rebuilt
Old 10-20-2018, 10:33 PM
adam_h22's Avatar
Default new engine rebuilt
hi everyone..
im new here and i have a question.
this is the second time that my engine destroyed because main bearing failure.
now im recived my new engine and im thinking to replace the main bearing with king/ acl bearing.
what do you think about this? any suggestion?
Old 10-21-2018, 07:33 AM
Car Analogy's Avatar
Received 1,315 Likes on 993 Posts
I think if you are asking for more problems if you replace the bearings. You are more likely to cause the very problem you seek to avoid.
Figure out what you did wrong with the first motor, and don't do that again. If you don't do something stupid, these motors will last 300k+ miles of enthusiastic use.
Old 10-21-2018, 08:45 AM
Charper732's Avatar
Every motor I've had come through my shop that had issues, has had worn mains. I tell everyone I know that gets a used engine "replace the bearings before you put the motor in" It's cheap and can save you a future headache. You just need to make sure the journal bores on the block and the journals on the crank are within spec.
Anyone telling you it's a bad idea to replace bearings is ignorant and does not speak from any experience.
Old 10-21-2018, 08:54 AM
adam_h22's Avatar
A lot of people with 09 model had this problem.
I’m never drive with cold engine and oil always was full...because of this I don’t think the problem is with me.
Old 10-21-2018, 09:03 AM
noodels's Avatar
So if your going to replacing them go OEM and fitted by someone who knows how to
Old 10-21-2018, 07:34 PM
Except he doesn't have a motor with issues. His old motor had issues, and now he's getting a 'new' motor (presumably a decent used motor without issues).
Taking it apart to fit aftermarket bearings is not a good idea imo.
Old 10-21-2018, 11:37 PM
noodels's Avatar
So is it an 09MY check end float also, how many miles ?
Old 10-22-2018, 12:54 AM
adam_h22's Avatar
The first was with 67k and the second with 50k
Old 10-22-2018, 09:46 AM
Charper732's Avatar
You don't notice main bearings issues until its too late. Main bearings on these motors wear down. period. and 99.9% of the time the center main. How many of these engines have you taken apart and inspected?
Old 10-22-2018, 05:30 PM
None. But I know there are people with 300k+ miles on their original motor, that is still going strong. So its not like stock bearings fail on all motors.
I maintain that just blindly replacing mains with aftermarket bearings is not a good idea.
Quick Reply: new engine rebuilt
