noisy transmission
Throwout bearing? Mine completely came apart and would make grinding noises and be very rough when pressing in the clutch pedal. When I swapped trans/clutch, the ball bearings fell out of the trans case as it had come unsealed. You might need to isolate this issue a bit more. When does it make noise? Under load or in certain gears? When engaging/disengaging the clutch?
it makes the noise when clutch is engaged and accelerating, complete clutch replacement including throwout bearing less than 5K miles ago so think I can rule that out.....
I think a thorough description of the sounds being made would be good. So when clutch is engaged it makes a buzzing noise? Is it at all speeds and all gears? Is it in neutral as well? Changes with engine revs?
