Car idles at 1500 rpms when fully warmed!!
Old 11-16-2018, 06:09 PM
04s2000ATX's Avatar
Default Car idles at 1500 rpms when fully warmed!!
Just bought a s2k but notice it’s idling higher than usual. It sits at 1500 rpms. Any causes or problems I should look after.
Old 11-16-2018, 08:45 PM
Zer0ne's Avatar
Try the idle relearn procedure.
Pull "backup" fuse under dash for ~10 minutes. Put back in, start the car with all accessories powered off. Let engine warm up to temperature and let the radiator fan cycle 2-3 times.
Old 11-17-2018, 03:33 AM
04s2000ATX's Avatar
I’ve done it a couple of times already and doesn’t seem to help, maybe I’ll try cleaning out the iacv today and see what happens.
Old 11-17-2018, 04:59 AM
Chuck S's Avatar
Received 1,128 Likes on 991 Posts
Proper amount of slack in the throttle cable?
-- Chuck
Old 11-18-2018, 10:24 AM
04s2000ATX's Avatar
Throttle cable is good. No cel light whatsoever. So when I drive and come to a complete stop the rpms slowly but stay around 1300 rpms. I did try cleaning the iacv with some brake cleaner but nothing has changed.
Old 11-18-2018, 12:18 PM
noodels's Avatar
Cleaned TB plate?
Old 11-29-2018, 09:26 AM
s2000ellier's Avatar
vacuum leak somewhere
Old 11-29-2018, 12:32 PM
S2kAndTheAnt's Avatar
I agree.
Old 11-30-2018, 11:00 AM
04s2000ATX's Avatar
I’ve searched for leaks and haven’t found anything. I’m not sure how good skunk2 throttle body are, maybe that’s causing the revving. I’m clueless
Old 11-30-2018, 11:52 AM
noodels's Avatar
Yep
swap old back in for sure.may have problems with TB
Quick Reply: Car idles at 1500 rpms when fully warmed!!
