Tyre Choice (2018) 50/50 Track and Street
So I've been browsing the S2ki board for tyre recommendations, and finding mostly they are US posts recommending difficult to get hold of tyres in the UK, or posts from 5 years old, so I thought I would post up for opinions on tyres available in the UK right now.
So following on from a great track day at Oulton Park at the weekend, it was apparant that the OE 16" tyres of dubious brand got me about 5 or 6 decent laps before heating up and feeling like jelly. So the 16's are going, and I'm looking out for some OE V1's or V2's to replace them, so I'll be looking at 17" tyres.
So Im after a tyre for a 50/50 split between track days and weekend jaunts, probably only when the sun in shining so wet tyre use not that important to me. Looking at recommendations, it seems the AD08R's get a good rep, the AO48's and perhaps the Toyo R888 (R) too.
So looking for people with track day experience really to give me the low down on the best tyre available that will suit, that will fit under non-rolled arches, and whether the staggered 215/245 setup works well.
Thanks
Chris
Thanks
Chris
i managed 3 laps on AD08rs up front at Donny before being flagged for noise, they are good
not great cold and poor in damp & cold but that doesnt seem relevant. i am fitting to the rear next.
a cheap seller on ebay called ckhk_concept
UK Moderator
Start with these posts:
https://www.s2ki.com/forums/uk-irela.../#post23172378
https://www.s2ki.com/forums/uk-irela...k-here-900533/
https://www.s2ki.com/forums/uk-irela...v0-3-a-582446/
I managed fine on the 16s (various Bridgestone options, latterly the excellent RE002s). I did use R888 for a little while and they were great on track but horrid on the road, very noisy and made the ride very bad.
If you're determined to go for 17s, then I'd keep the 16s and put some track tyres, and use the 17s for the road along with some Michelin PS4.
If you want an all rounder for track and road, then AD08R is the go to option.
I think I'd give the Hankook RS4's a go if I were you. Supposed to be grippy and decently long lasting (compared to RE71s anyways).
What’s your budget? That’d be a good starting point I think. Cheap would be Bridgestone RE002 or Uniroyal Rainsport 3’s (added benefit of been an epic wet road tyre and seen on most enduro cars as the wet tyre choice). Toyo R888/R888R and Nankang AR1’s are a solid track tyre, with some comprises for road use. AD08R’s are quite a loved tyre, but don’t think they compare to the Nankangs/Toyo for track duties. Theres more serious options too but that requires more spends.
Would also go 225/255
Ohlins lowered 25mm with no fender mods..
Had Rainsports on car when I got it,215/245
Federal 595 rsr 225/255
Now on AD08R 225/255 <are lighter than 595rsr>
The Nankang Ns2R on the Civic are <VERY loud>
If I could afford 888R it would be my choice
Another thumbs up for the PS4’s, I fitted a full set for a trip down to the Italian lakes recently and found them to be way better than the Conti Sport 5’s on the motorways and even better on the passes .A little bit more road noise but worth that for the extra grip wet and dry. 17” by the way.
