AC Not Working
AC Not Working
Will try to get to the point, AC is not working. Compressor turns on and off, Freon level is good, heater control box is working. What I noticed is the AC lines are not getting cold and there is no condensation forming on them (Florida). Car is an 02 with 39k.
Thanks
Thanks
Used oem works better than remanned or aftermarket, my used OEM compressor is still kicking.
You will likely have to replace the high pressure line going from the compressor to the condenser as well, if indeed your compressor failed as there are likely metal shards all up in it. This is the hose most likely to leak.
You'll also need to clear out the condenser(acetone and compressed air works best), luckily the drier catches most of the crud and the expansion valve doesn't really allow much to enter the evaporator. I would swap out both drier and expansion valve they're cheap parts and are pretty universal, so you don't have to buy OEM ones.
The system takes PAG 46 oil only thing not clear in the service manual. I'd also get a set of o-rings, if you're going to take apart the system make it as new as possible to minimize any future maintenance.
