Mark this thread as Unsold
CA Massive OEM and aftermarket part out
Price: 1-1000
Contact: call/text 949-872-8270 or alanlee153@gmail.com
If you don’t see something on this list you need PM or text me, I may have it. Inventory is always changing. Prices are also subject to change depending on color, condition, and market conditions.
Prices are accurate as of 11/20/2018!
All parts listed are for 2000-2009 Honda S2000
Will only ship small to medium sized parts. Will not ship to other countries outside of the USA, Hawaii, Alaska, Guam, and Puerto Rico unless the buyer wants to pay the very high shipping costs. No trades.
INTERIOR:
CR seats w/ sensors and rails, driver has small hole in bolster - $1500 pair
OEM s2000 key fob - $30-$50 depending on condition
00-03 radio door w/ black frame, black - $40
02-03 full red door and frame, 9/10 will fit 00-05 - $100
S2000 start button - $40 shipped
Passenger side window regulator - $150 FIRM
Driver side window regulator - $125 FIRM
00-05 roll hoops, not split, black - $100
06+ roll hoops with speakers, black - $300
AP1 center console 7/10 condition - $50
00-05 carpet, black, pair, no holes - $120-$250 depending on condition
06+ carpet, black, pair, no holes - $150-$250 depending on condition
AP1 steering wheel w/ airbag - $150-$250 depending on condition
00-05 seats, black, $350 - $600 depending on condition
00-05 passenger airbag w/ cover, black - $100
06+ passenger airbag w/ cover, black - $100
00-05 seat belts, driver and passenger - $75 each
06+ seat belts, driver and passenger - $75 each
00-05 seat belt receivers - $50 pair
06+ seat belt receivers, driver and passenger - $75 pair
00-01 door panels, black - $100
02-03 door panels, black - $150
04-05 door panels, black 8/10 condition - $300 FIRM add $50 for window switches
Tan leather center console cover - $50
Black leather center console cover - $100
Red leather center console cover - $125
Spare tire anchor - $5
Map light - $20
A pillar plastics, driver and passenger - $20 each
Soft top motors – $20 each
Complete 02-03 red interior excepts for seats, 8/10 condition - $2,500 FIRM
Complete foam tool box and all tools - $60 FIRM
06+ instrument cluster - $250
04-05 instrument cluster - $275
08-09 instrument cluster - $275
All interior plastics, black – call/text for pricing
EXTERIOR:
Headlight brackets sold in pairs $60 each side
AP1 fender liners - $120 pair
Lower engine covers - $50 for pair
Rear trunk lid, silverstone, no holes, some dings, no holes 7/10 condition - $250
3rd brake light, 9/10 condition - $100
Front hood latch - $35
Rear trunk latch - $35
AP1v2 rear tail lights - $150-$250 depending on condition
AP2 rear tail lights, no cracks, no dust - $350- $400 depending on condition
AP1 front crash beam - $75 add impact foam $25
AP2 front crash beam - $100 add impact foam $25
AP1 & AP2 rear crash beam - $50
Driver side door, in black, rio, silverstone, spa - $200 each
Passenger side doors in Silverstone, sebring, black, spa - $200 each
Driver and passenger mirrors, white, black, rio - $50 each
Door window molding trim - $40-$60 depending on condition each side
AP1 headlight housings - $300-500 depending on condition
AP1 ballasts - $100
AP2 ballasts - $100
OEM HID bulbs - $25 each
Antenna - $20
Driver and passenger side door window glass - $30 each side
Silverstone front fenders, not rolled - $350 each side
Black front fenders, not rolled - $350 each side
DRIVETRAIN:
AP1 driveshaft - $80, 30 day warranty
AP2 driveshaft - $125, 30 day warranty
AP1 transmission, good condition, 30 day warranty - $600
AP1 differential, good condition, 30 day warranty - $450
AP2 transmission, good condition, 30 day warranty - $800
AP2 differential, good condition, 30 day warranty - $550 FIRM
Axles - $100 each side, 30 day warranty
SUSPENSION:
Brake calipers, 00-05, front and rear 00-05 - $50 a pair
Brake calipers, 06+, front and rear - $75 a pair
Front spindles, hubs, knuckle - $125 each
Front lower control arms -- $100 each
Front upper control arms -- $60 each
Rear spindles, hubs, knuckle - $175 each
Rear upper control arms, AP1 - $75 each
Rear lower control arms - $100 each
00-09 front and year sway bars - $30 each
Front and rear camber and toe, alignment adjuster bolts - $40 each
Rear toe arms - $25 each
AP1 Front and rear subframes, no bent tabs - $150 each
AP2 rear subframe, straight, no bent tabs - $250
AP1 steering rack w/ torque sensor - $250
AP2 steering rack w/ torque sensor - $250
06+ steering rack w/ torque sensor - $300
ENGINE:
00-05 OEM intake, complete - $100
06+ OEM intake, complete - $125
OEM catalytic converter - $200 FIRM
Headers w/ heatshields - $50
Battery heat shield - $20
AP1 spark plug cover - $40
AP2 spark plug cover - $60
00-05 fuel rail - $50
Fuel rail cover, all years - $20
Fuel injectors, set of 4, all years - $100
00-05 coil packs x4 - $100 or $30 each
06+ coil packs x4 - $125 or $35 each
Transmission brace w/ bushings - $40
Rear diff mounts, all 4, not cracked - $80
00-05 Oxygen sensors, primary and secondary O2 sensors - $60 each
06+ primary 02 sensor - $100
06+ secondary 02 sensor - $75
00-09 ABS sensors, wheel speed sensors, all corners - $40 each
Radiator air dam - $30
EGR valve - $25
Upper intake manifold 06+ - $100
00-05 Throttle body w/ sensors - $60
06+ DBW throttle body - $100
Gas tank - $50
00-05 fuel pump and sending unit - $50
00-05 radiator w/ fans - $80
00-03 EPS module - $60
04-05 EPS module - $60
06+ EPS module - $75
00-05 SRS module - $50
06+ SRS module - $75
Entire A/C system - $200
AP1 valve cover, paint chipping - $50
Engine oil pan, rethreaded w/ time-sert - $75
OEM starter, 30 day warranty - $50
OEM alternator, 30 day warranty - $80
Fuse Boxes - $25
Washer tank w/ pump $25
Wiper blade arms - $20
WHEELS:
Multiple sets of AP1 wheels - $150-$300 depending on condition
OEM lug nuts - $25 a set
Spare tire - $30
AFTERMARKET:
Radium fuel rail kit for w/ Radium fuel pressure gauge - $200
Radium fuel surge tank kit w/ Walbro 255lph fuel pump - $800
DeatschWerks fuel pump 255 LPH BNIB - $80 Shipped
AFI fuel injectors 750cc x4 w/ pigtails fits 00-05 - $200 shipped
Omni Power USA 4 bar map sensor MAP-BDHF-4BAR fits: 00-05 - $70 shipped
Injector Dynamics ID1050x x4 w/ pigtails fits 06+ - $400 shipped
Mugen replica HT, Laguna blue, excellent fitment, comes with fixed brackets - $1200 FIRM
Authentic Mugen CF HT BNIB - $6,000
OEM Hardtop, Laguna blue, 7/10 condition - $3,700
Honda Access floor mats, black, BNIB - $250
Buddy Club N+ coilovers, perfect shape, no leaks - $600
Buddy Club front RCA, ball joints, $250
ASM IS 11 seat w. driver side seat rail - $1300
Sparco QRT seats $700 BNIB
Sparco roadster seat w/ rail $240
Planted seat bracket passenger, new, 06+ - $100
J’s racing 3D GT wing type 2, 1600mm, 245mm stands, 1 end plate has a small chip, there are also small clear coat cracks at the very edge on 1 area 8/10 condition - $1,800
Airwalker sideskirts, painted Sebring - $250
Price: 1-1000
INTERIOR:
Map light - $20
EXTERIOR:
AP1 ballasts - $100
AP2 ballasts - $100
Antenna - $20
DRIVETRAIN:
SUSPENSION:
ENGINE:
EGR valve - $25
Gas tank - $50
Fuse Boxes - $25
WHEELS:
Spare tire - $30
AFTERMARKET:
