NGK Iridium spark plugs
I replaced the plugs in my Honda Element, today. I noticed the "double platinum" photo on the back of the box. Iridium plugs are now platinum? Thanks!
I know they put a platinum disc on the ground electrode, not sure how they get the other half of the double platinum, unless they put a thin platinum coating over the iridium centre electrode metal ? Those are Iridium plugs though. It's been a few years since I used them, they may have made some small changes to them. I tend to use the NGK IX Iridiums on my vehicles with the ground centre electrode, no platinum mixed on them.
I like NGK Iridium BKR8EIX. One step colder so good for boost and they make a tangible difference on NA as well. Compared to stock PFR7S I feel more power and engine response. Obviously not a huge difference but you'll know it when you feel it. Very good plugs.
NGK 6994 IZFR6K11. For 2007 Honda Element.
You can get a slight performance improvement over thinner center electrodes and tapered ground electrodes which some iridium plugs offer. A fine wire center electrode and a tapered ground electrode tends to offer the best performance as the spark is better exposed to air/fuel mixture, bigger quench as the spark goes from sharper edge of the center electrode to the sharper edge of the ground electrode.
Note how this one says: "Iridium:Platinum." And the new ones I put into the Element just says "Double Platinum." Wonder if NGK is changing formulation?
^ They do produce both products, and they are different.
UPDATE. Iridium spark plugs for S2000 are Iridium/Platinum. At least for now.
