V12 swap
Old 02-19-2019, 10:42 AM
S2000fan1's Avatar
Default V12 swap
I was thinging about taking my car in and getting a 1gz fe v12 swap, but was wondering, what would the cost be to do this? Thanks.
Old 02-19-2019, 10:48 AM
S2000fan1's Avatar
Default Maybe
To clarify, I am not planning on it, mainly just curious.
Old 02-19-2019, 10:49 AM
Site Moderator
Manga_Spawn's Avatar
Pretty sure it has never been done so no one is going to be able to tell you a price. It won't be cheap and there is going to be a lot of custom fabrication and things to figure out.
Old 02-19-2019, 11:11 AM
s2000Junky's Avatar
Oh boy Safe to say it will cost you more then you could sell the car for and plan on at least a year for a specialty shop to give you a final product with no guarantee it will be reliable and solid. A V8 swap on the other hand has been done numerous times, and there is a off the shelf mounting kit from Import Muscle that gets you at least 50% of the way there right out of the gate. Total install cost minus the few grand for the motor seems to be right around 10k conservatively. Its still a lot of fab work and tuning stuff.
Old 02-19-2019, 11:43 AM
Site Moderator
Not to mention the same snowball effect that boost has on this car but even worse. Swap the engine you have to figure out a transmission solution. No way the OEM trans will hold the power so you try to use something else. Now the diff is a problem and making everything fit is also a problem. Custom driveshaft, axles, mounts, wiring, engine management, cooling, etc etc etc.
Old 02-19-2019, 11:54 AM
Kyle's Avatar
Whole lotta nope in this thread
Old 02-19-2019, 12:02 PM
TsukubaCody's Avatar
PM the user Ricky_Flowers_ he did this same swap back in 2012.
Old 02-19-2019, 12:07 PM
s2000Junky's Avatar
your cruel man.
Old 02-19-2019, 12:14 PM
Site Moderator
sam_spider's Avatar
Received 2,587 Likes on 1,903 Posts
Probably shouldn't start a battle with Ricky, it typically doesn't end well for the other party.
Old 02-19-2019, 12:23 PM
No beef, I don't want to steal his props. Much respect to the OG.
Quick Reply: V12 swap
