Low Pressure AC Line
Old 02-20-2019, 06:46 PM
Benji ap1's Avatar
Default Low Pressure AC Line
I need a replacement low pressure AC line for my AP1 s2k. Is an AC receiver pipe or AC suction pipe the same thing as the low pressure line?
Old 02-21-2019, 02:35 AM
Slowcrash_101's Avatar
Yes but I made a mistake, the hose that leaks is the one that goes from the compressor to the condenser which is a high pressure line IE a discharge hose. My apologies.
Old 02-21-2019, 02:48 AM
Benji ap1's Avatar
So is the suction pipe the same thing as the low pressure line?
Old 02-21-2019, 01:21 PM
Yes, that is the line from the evaporator to the compressor. Its called the suction side because it's drawing in the refrigerant as a gas. Compressing(hence the name compressor) it and sending it as a liquid to the condenser. Condenser removes heat from the compression process, then the liquid passes through the drier canister into the expansion valve which meters refrigerant into the evaporator, and the cycle starts over.
Kazkaz
02-27-2019 11:28 AM
Charper732
01-30-2017 03:11 AM
chicomacattack
08-25-2015 09:42 PM
Mr._ap1
04-11-2013 05:22 AM
dominion
07-19-2008 08:02 AM
Quick Reply: Low Pressure AC Line
