Reman'd Alternators
Old 03-18-2019, 07:14 PM
s2000adventures's Avatar
Default Reman'd Alternators
Unfortunately I haven't had any luck tracking down a locally used OEM alternator... therefore I am turning to the aftermarket...
Are there certain manufactures that you have tried that turned out good for you? There are a few re manufacturers on Rock Auto (e.g. Denso, ACDelco, Remy Power Select).
Old 03-18-2019, 09:10 PM
Kyle's Avatar
Denso is the original manufacturer of the OEM alternator.
Old 03-18-2019, 09:22 PM
indi00's Avatar
Worst mistake ever was buying a brand new ebay alternator for $120. It was new and shiny and unbranded. In less than a year, the voltage regulator went out putting 17+ volts to the battery and killing the battery. Before that, the car would be hard to start when the engine was hot and left me stranded at the gas station. And then the car would occasionally shut off when coming to a stop because the RPM would dip too low. I hated the car. After killing my battery, I bought a used OEM alternator on ebay for cheap and it solved everything. I replaced the brush for reassurance. After that, all my electrical gremlins went away.
Old 03-19-2019, 06:26 AM
solitarycheese's Avatar
My alternator was still charging the battery, but I had a bad rectifier causing the dash to flicker. I went through one DENSO reman alternator (purchased from Amazon), and two Autozone/Duralast alternators. I got one that worked fine for a a year, but my dash started flickering again. I purchased a rectifier from this seller https://www.ebay.com/itm/100-NEW-ALT...frcectupt=true on the reccomendation of this message board and it works great.
f I were to do it over again, I would have kept my original DENSO alternator and done a complete rehaul myself, it is really easy and instructions are laid out in the service manual (there's also nothing unique about the S2k alternator so a generic guide will work as well).
Old 03-20-2019, 08:42 AM
impulse21's Avatar
Just stick to a name brand refurb like denso/bosch..
Old 03-22-2019, 10:41 PM
jyeung528's Avatar
years ago, i bought an oem rectifier and rebuilt myself.
hopefully these rectifiers are still available for sale from Honda.
mine is still going strong.
deepbluejh
02-26-2013 11:23 AM
EPM04
09-16-2011 10:21 PM
Dumas2k
07-22-2010 07:43 AM
frofro24
08-05-2008 08:01 PM
BeerWill
06-02-2006 10:56 PM
Quick Reply: Reman'd Alternators
