New OEM complete clutch installed purchased from honda. Wobble sound help
Old 04-19-2019, 03:50 PM
v10killer's Avatar
Default New OEM complete clutch installed purchased from honda. Wobble sound help
Recently had a clutch installed and now there is a wobble when engaging the clutch in reverse from a stop. Also a noise. Here is a link to the sound.
https://m.youtube.com/watch?v=eLO5U_yuUCY
Old 04-19-2019, 03:51 PM
v10killer's Avatar
Old 04-19-2019, 05:46 PM
windhund116's Avatar
Received 1,424 Likes on 954 Posts
Sounds like something is rubbing. You take it back to the dealer, who installed it?
Old 04-19-2019, 06:35 PM
Chibo's Avatar
What clutch disk, pressure plate, and flywheel are in use. Were the two bearings replaced?
Old 04-20-2019, 06:45 AM
v10killer's Avatar
All parts used were from the honda dealership.
Old 04-20-2019, 07:10 AM
v10killer's Avatar
Here is the work order
Old 04-20-2019, 08:30 AM
Are you close to the dealer who did the work? I'd take it back. They must have a warranty on their work.
Good luck!
Old 04-20-2019, 08:47 AM
starchland's Avatar
Wow that’s that’s a lot of coin, damn right they will make it proper
Old 04-20-2019, 10:42 AM
flanders's Avatar
Not sure what it could be but you should definitely take it back, you should ask them what kind of grease they used for the release bearing as well.
Old 04-20-2019, 10:48 AM
v10killer's Avatar
Could it be the shifter not regreased properly? I'll definitely take it back to see though.
Quick Reply: New OEM complete clutch installed purchased from honda. Wobble sound help
