Spark plug state check
Old 05-25-2019, 07:04 AM
KY Moon's Avatar
Default Spark plug state check
Hello s2ki,
I drive f20c swapped e46 as daily car.
Previous car was dc5 rsx.
Even if i experienced vtec, f20c was quite differerent from k20a.
One of diffenrent thing is oil consumption
Maybe about 1200km per 1 liter even if i drive over vtec range to test f20c.
There was no oil leak out side of engine.
Engine power was not bad.
Fuel economy was over 13km/L on highway.
When i change spark plug, old plugs were as below.
I could confide only cyl#1 is okay.
But, Cyl#2, 3 and 4 had oily stuff around tip.
How do you think my plug state?
Is it into the normal range?
Thank you in advance.
Old 05-25-2019, 08:06 AM
OMG VTEC's Avatar
Relatively normal burn, a little on the rich side. It would be important to include the mileage of the plugs.
Old 05-25-2019, 03:20 PM
KY Moon's Avatar
Thank you for your answer.
I'm not sure. Maybe mileage is around 20~30k km.
Old 05-25-2019, 03:51 PM
zeroptzero's Avatar
Received 3,361 Likes on 2,444 Posts
1,3, and 4 look normal, plug #2 is perhaps burning a bit more oil or running more rich. Swap the plugs in different cylinders and check back later down the road and see if the pattern changes. I don't see any big issues with the plug conditions.
Old 05-25-2019, 07:02 PM
KY Moon's Avatar
Thank you for your advice.
I'll monitor again.
Old 05-26-2019, 10:36 PM
nubbel's Avatar
What does your Long Term Fuel Trim say?
Get a cheap Bluetooth ODB2 scanner and read LTFT via a free app on your phone.
FireDog
09-13-2013 02:08 PM
fivlemon
07-18-2008 01:06 AM
taz5
10-10-2007 09:02 AM
Kenpo_S2000
01-13-2006 04:27 PM
fish
08-06-2001 11:59 AM
Quick Reply: Spark plug state check
