05 2000 GPW with dirt on side skirts. It only removed with vinegar and water.
Old May 25, 2026 | 03:39 PM
Paradoxicalcook's Avatar
Default 05 2000 GPW with dirt on side skirts. It only removed with vinegar and water.
Any suggestions on how to fix this permanently? Vinegar solution will remove it temporarily. What do I need to do to remove it permanently? It only happens only on lower skirt and front and rear quarter panel on both sides. Thanks!
Old May 26, 2026 | 04:39 AM
Chuck S's Avatar
Old May 26, 2026 | 06:41 AM
TsukubaCody's Avatar
We probably need photos to understand what you’re trying to describe.
Old May 26, 2026 | 06:48 AM
engifineer's Avatar
Sure it isnt tar? have you been driving on a newly finished or refinished road? that can be harder to remove (Stoners makes a good product for it).
Old May 31, 2026 | 10:32 AM
JulieU's Avatar
Administrator
If it's tar, try Nu Finish.
Old Jun 5, 2026 | 04:56 AM
Default Examples
Here are examples of what I keep having happen after a wash. It is not tar. Is there a product I should put on it to prevent this other than a standard wax? Thanks for suggestions!
Old Jun 6, 2026 | 06:05 AM
Chuck S's Avatar
Just checked my car as I thought that might be the factory coating applied to the lower body area but that starts after the under-curve at the very bottom.
You've apparently owned this car for over 20 years, but this has this magically occurred this spring? Change in venue or roads driven? Did you apply a tape stripe to this area and later remove it?
-- Chuck
Old Jun 6, 2026 | 09:51 PM
JBamin's Avatar
are you taking it through a car wash tunnel by chance? did you elect for the tire shine option on your package? this looks like the tire shine application brushes are actually rubbing up on your car because its a low sports car.
Old Jun 9, 2026 | 01:37 PM
You nailed it! I broke my shoulder last year and couldn't wash my car until very recently. Thanks!
Old Jun 9, 2026 | 09:22 PM
JBamin's Avatar
the tire shine product they use in tunnel washes is a heavy silicone based product. you'll need to find a heavy degreaser or another product that can remove or loosen the silicone. that stuff is thick and will require some physical agitation as well as chemical remover.
Saki GT
Sep 27, 2022 08:30 AM
finalleaf
Sep 24, 2018 09:33 PM
buenrostrox
Apr 15, 2010 04:55 PM
