California - Southern California S2000 Owners Southern California S2000 Owners
Evasive S2KI Service & Maintenance Thread
Old 09-30-2011, 06:00 PM
EvasiveMotorsports's Avatar
Default Evasive S2KI Service & Maintenance Thread
Evasive Motorsports would like to give another introduction of our service department to both current and new members of the S2000 community. Most of S2KI members are aware of service we provide but to those who aren't, we provided a list our most common services. Our knowledge and experience allowed us to be capable of diagnosing and rebuilding everything from engine/transmission rebuilds to diagnosing suspension and chassis issues. We also stock full inventory of Motul, Amsoil, along with Project Mu and Endless brake fluids.
Our facility operates Monday-Friday 9am-6pm. Feel free to PM or call us at (626) 336-3400 if there are questions or services you would like to have done that may not be listed below. (Note: Pricing below is for service only and do not include parts unless specified.)
For those who would like to reflect our current S2KI service special to our old service thread, it can be viewed here - https://www.s2ki.com/s2000/topic/757...e-maintenance/
Basic Service & Maintenance
Oil Change - $95.00 (includes Motul 8100 or Amsoil and genuine Honda oil filter)
Transmission - $70.00 / $95 (for Amsoil) (includes genuine Honda MTF or Amsoil Syncromesh)
Differential - $60.00 (includes Motul Gear 300 or Amsoil Severe Gear 75w90)
Coolant Change - $150 (Includes Honda Coolant)
Brake Bleed - $135.00 (includes Motul RBF600)
Brake Line install - $250 including Flush and fluids
Brake Pads & Rotor Install - $140.00 (Fronts or Rear Only $75)
Intake - $75.00-$125 -
Exhaust - $75.00
Header - $200+
Valve Adjustment - $175 (with gasket)
Clutch - $500.00 (fluids not included)
Clutch Master - $325 (includes new OEM Clutch Master and Fluids)
Wheel Bearing Replacement - $400 per corner (includes genuine Honda hub & wheel bearing)
ARP Extended Studs- $450 Including Wheel Bearing / Hub Service listed above labor only per corner (Does not include Extended Studs)
15k/45k Service - $225/$250 (includes Motul 8100, genuine Honda oil filter/MTF, Diff (Motul Gear 300), inspect brakes/belts/fluids/air pressure/joints/seals - top off all fluids) Turbo/Supercharged cars May require additional charge
30k/60k - $425/$450 (includes genuine Honda coolant/air filter/accessory belts in addition to 15k Service items listed above)
Suspension & Drivetrain Components
Alignment - $90 (any spec)
Corner Balance - $250 (includes 4-wheel alignment)
Coilover - $200.00 (including coilovers which reuse top hats - KW, Tein,) / JRZ / Motons (+$40)
Height Adjustment - $20 Per Corner
Springs - $225.00
Sway Bar - $75.00 Fronts $50 Rear
Differential Collars - $100.00
Half-shaft Spacers - $80.00
Front Camber Joint - $125 (J's Racing/Spoon type)
Rear Roll Center Adjuster - $175.00 (J's, Hardrace)
Rear Bump Steer Kit - $125.00
Under Brace - $50.00
Rebuild Axles + Install - $500
Final Drive - $400.00 (additional $150.00 if diff needs to be taken off car) (fluids not included)
Aftermarket LSD - $400.00 (additional $300.00 if diff needs to be taken off car including all bearings, shims etc.) (fluids not included)
Final Drive + LSD - $500.00 (additional $150.00 if diff needs to be taken off car) (fluids not included)
Motor Mount install - $300.00
Bushing Kit replacement - PM/Call
EVS Alignment Tab reinforcement/replacement - $120.00/section
Nitrogen Shock refill - $60.00; $20.00/shock
Re-Weld Titanium Exhaust - PM/Call
Re-Weld Titanium Bungs - PM/Call
Exterior & Aero Service
Tire Mount/Balance - $20.00/wheel
Tire Dismount - $10.00/wheel
TPMS - additional $5.00/wheel
Fender Roll - $75.00/corner (+$20 for bumper tab relocation)
Hardtop install - $200.00 (OEM, Mugen)
Softtop removal - $375.00/$400.00 for removal + $125 for install
Roll Bar install - $750.00 (Cusco / Mugen / +100 for Harddog)
Roll Cage install - $1000
Steering Wheel/Hub install - $125.00
GT Wing install - $250.00
EVS Custom Front Splitter - PM/Call
EVS Custom Flat Belly - PM/Call
EVS Custom Roll Cage - PM/Call
EVS Custom Extended Lower Control Arms - PM/Call
FULL CUSTOM ECU DYNO TUNING AND REFLASH
Full custom ECU tune - PM/Call
Dyno Power Check - $100 3 pulls
Hondata Flash Pro NA $450
Hondata Flash Pro Boosted - $650
Hondata K-Pro - $200 a hour
AEM EMS - $200 a hour
AEM Infiniti - $250 a hour
Reflash - PM/Call
Supercharger or Turbo Install - PM/Call
Fuel system Install - PM/Call
Give us a call! 626-336-3400
Address: - 11829 Hamden Place, Santa Fe Springs, CA 90670 (main intersections Pioneer/Telegraph)
Web: - www.evasivemotorsports.com
Blog: - blog.evasivemotorsports.com
Evasive Service Calender
Hours of Operation: Monday-Friday 9am-6pm
Contact: (626) 336-3400
Email: joshua@evasivemotorsports.com
Old 10-01-2011, 12:21 PM
QuagmireS2k's Avatar
Seems like fair pricing on all services. You guys sure have grown since your first location.
Old 10-03-2011, 06:37 AM
kaotik25's Avatar
Bump for Evasive, the only place I trust for my S2000 . Will continue to do business.
Old 10-03-2011, 07:12 AM
NFR_AP2's Avatar
wish i lived in cali :/
Old 10-03-2011, 09:14 AM
niahuynh's Avatar
Old 10-03-2011, 09:18 AM
kaotik25's Avatar
It's not too late to move to sunny southern Cali. Everything is nice here minus the traffic and smog. LOL!
Old 10-06-2011, 08:23 PM
99SH's Avatar
Originally Posted by EvasiveMotorsports
Clutch - $300.00 (fluids not included)
Am I reading this right? Clutch job for $300?
Old 10-06-2011, 09:39 PM
HvRRZ's Avatar
How much to install a new diff housing?
Old 10-12-2011, 01:07 AM
tlee1234's Avatar
Just did my alignment today at Evasive, Thumbs up, they gave great recommendations, and car feels great! Thanks guys
Tony
Old 10-12-2011, 05:10 PM
skylinrcr01's Avatar
Evasive, good group of guys
Quick Reply: Evasive S2KI Service & Maintenance Thread
