Best Fuel Injector Cleaner?
Old 09-02-2012, 02:12 PM
EnvyMyS2K's Avatar
Default Best Fuel Injector Cleaner?
As the title says what's the best fuel injector cleaner for the S?
Old 09-02-2012, 02:31 PM
trapper's Avatar
I use 1/2 of a bottle of "Red Line Complete Fuel System Cleaner SI-1" in a full tank of gas about once a year.
Old 09-02-2012, 02:45 PM
whiteflash's Avatar
BG44K / BG Fuel injector cleaner
Redline also makes great products
Old 09-02-2012, 02:52 PM
sillyboybmxer's Avatar
Originally Posted by trapper
I use "Red Line Complete Fuel System Cleaner SI-1" in a full tank of gas about once a year.
i swear that stuff fouled by plugs. Car had plugs about 1 year old and about 10k miles, ran a tank of that stuff and when i filled up again my check engine light came up, pulled the code and it was for engine misfire and random cylinder misfire,....changed the plugs and i was good to go.
i dont know why it did this but i am a believer that our gas we run has enough cleaners in it to begin with and we don't need additional treatments
Old 09-02-2012, 03:51 PM
GSteg's Avatar
I wouldn't dump a whole bottle of Redline in the tank. Our tank is small so the concentration will be slightly stronger. I usually put in maybe half a bottle for every full tank.
Old 09-02-2012, 04:03 PM
s2000ellier's Avatar
i used the chevron with techron bottle
Old 09-02-2012, 04:34 PM
S2KIrishman's Avatar
i used lucas because i used to get it for free from the lucas rep that used to come in to my old shop...it seemed to work well, but its hard to tell
Old 09-02-2012, 05:52 PM
MM3Kwolik's Avatar
This^^ If I use a system cleaner, this is also what I use...
Old 09-02-2012, 06:04 PM
frankdatank91's Avatar
I usually sea foam my gas tank, oil and pcv vacuum line every few oil changes. works great!
Old 09-02-2012, 06:20 PM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
The cleaning chemical that is strong enough to work in one dose/bottle is PEA, Redline's fuel system cleaner is reported to have the highest concentration of PEA, followed by Chevron Techron. Regane used to have a decent amount of PEA but I'm not so sure about the new formula. One bottle of Redline is enough to do two tanks on the S2K, I used one bottle a year for good measure. I was surprised how clean my valves and intake ports were after 60k miles, not too shabby.
Quick Reply: Best Fuel Injector Cleaner?
