"MyS2000"
At work, 'MyS2000' shows recent threads I've posted in
At home, it always shows no threads, even if there are threads I've posted in that were updated since I last logged on :confused: |
I am not sure.. but is there a difference is versions of browser you are using
hmm, home is IE 6, I'll check work Monday :)
work is IE 5.5
Upgrade to 6 and see if it works :)
but 6 doesn't work so good :eek1:
clean out your cookies. You likely have a bad one.
cookies, temp int files, history all dumped already.
sigh |
that makes no sense then, its the same code whether you're at home or at work.
you've logged out and back in too right? What if you login as someone else? do they see the same behavior? |
| All times are GMT -8. The time now is 04:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
