Search is broken.
if I click on the search link at the top center it takes me to https://www.s2ki.com/forums/index.php?act=Search
and if I search for the word "anything" (just as a test), I get no results. But if I search for "rear axle" I get:
mySQL query error: INSERT INTO ibf_search_results (id,search_date,topic_id,topic_max,sort_key,sort_o rder,member_id,ip_address,post_id,post_max) VALUES ('5b51362b5e2b8ea91af12f3670a504de','1099735124',' 240992,240194,241134,241203,241229,241207,238603,2 41452,241472,240400,241735,241488,241870,241943,24 0133,241732,241376,240630,241920,232071,242109,242 273,240650,241840,230707,242013,242164,242629,2413 72,242879,243389,243554,242616,243549,243534,24372 6,243576,243627,243608,243507,243873,243823,244017 ,244032,243997,239178,99995,244402,244426,244061,2 43455,244599,244431,244620,244731,244423,244048,24 4870,244002,243905,244287,244871,245336,242758,245 304,245569,245508,245501,245137,245451,245757,2458 81,243361,245915,245371,225993,245990,245885,24620 1,246108,244406,48572,246254,246390,241031,246725, 246774,227808,246761,246777,242205,245186,244638,2 47223,246899,246500,247408,246954,247457,247418,24 6185,247416,247128,247583,247585,247620,247314,247 639,118889,245752','110','last_post','desc','26',' 68.209.223.242','4550422,4550442,4550552,4550562,4 550577,4550643,4550708,4550872,4550981,4551014,455 1149,4551154,4551156,4551224,4551352,4551376,45515 27,4551567,4551656,4551928,4552120,4552153,4552246 ,4552263,4552400,4552499,4552575,4552577,4552615,4 552657,4552704,4552721,4552791,4552844,4552897,455 2979,4552993,4553011,4553148,4553161,4553189,45531 92,4553213,4553247,4553292,4553299,4553316,4553339 ,4553340,4553367,4553389,4553418,4553431,4553512,4 553531,4553638,4553888,4553911,4553984,4554052,455 4078,4554080,4554090,4554249,4554277,4554283,45543 22,4554324,4554334,4554342,4554367,4554393,4554399 ,4554408,4554545,4554596,4554605,4554693,4554740,4 554836,4554913,4554977,4555023,4555043,4555093,455 5274,4555283,4555329,4555350,4555352,4555456,45557 06,4555814,4555875,4555997,4556026,4556045,4556047 ,4556099,4556114','100')
mySQL error:
mySQL error code: 0
Date: Saturday 06th of November 2004 01:58:44 AM
and I tried it with other words...apparently it doesn't like having a space between the words?
mySQL error:
mySQL error code: 0
I just did it and it ran fine
https://www.s2ki.com/forums/index.php?act=S...%22rear+axle%22
This topic was first on the list
. Let me know if you're still getting this.
Cthree,
For some reason search is using search_mysql_man, not ftextslave - eh? I left it as is cause I'm not sure why that change was made. Weasel takes forever and a half doing these kind of queries (I took out most of the forum id's):
SELECT p.pid
FROM ibf_posts p
WHERE p.post_date >1097149268 AND p.forum_id
IN ( 3, 78, 79, 81, 86.....121, 126 ) AND p.queued <>1 AND
MATCH (
post
AGAINST (
'keywords more keywords'
IN BOOLEAN
MODE
LIMIT 100
I'm too sleepy to think straight, hopefully you see this when you get up in a few hours
SELECT p.pid
FROM ibf_posts p
MATCH (
post
AGAINST (
IN BOOLEAN
MODE
LIMIT 100
Originally Posted by cthree,Nov 6 2004, 11:25 PM
Does that mean you're going to charge us for reaffirming it doesn't work?
