Search function (again/still)
Hi there,
I just found out that the search function still pretty much blows. Although the date sort option is a huge improvement, it would be very usefull if I could actually get some search results. Search keys such as "superlegga" gives me 1 result, "superleg*" with the suggested wildcard gives 0 results, "*superleg*" 0 results "hond*" 0 results Finally, it doesn't allow to search for terms of only two characters. So to find "OZ" is impossible. Could you possible fix this very annoying shortcoming..? Greetings! Siepel |
I think you need to modify your search technique, because:
1)"superlegga" appears to be a mispelling to me... I'm not surprised you only get one result. I'm assuming what you're trying to search for is "superleggera". 2)my guess is the owners of the board have turned off wild card searches, because they tend to suck up a whole lot of CPU, which they probably don't have available. Be thankful there's ANY search functionality (trust me on this one... I run a large portion of the backend search for a huge company that I guarantee you've heard of. And the amount of money we spend on hardware to facilitate what you're asking for would boggle your mind). 3)Although not being able to do 2 letter searches can be a pain, it eliminates a lot of "garbage" searches, which again is only done to better your experience here by not slowing things down to a crawl performing searches that are going to turn up hits against every post ever made. |
Originally posted by heffergm I think you need to modify your search technique, because: 1)"superlegga" appears to be a mispelling to me... I'm not surprised you only get one result. I'm assuming what you're trying to search for is "superleggera". 2)my guess is the owners of the board have turned off wild card searches, because they tend to suck up a whole lot of CPU, which they probably don't have available. Be thankful there's ANY search functionality (trust me on this one... I run a large portion of the backend search for a huge company that I guarantee you've heard of. And the amount of money we spend on hardware to facilitate what you're asking for would boggle your mind). 3)Although not being able to do 2 letter searches can be a pain, it eliminates a lot of "garbage" searches, which again is only done to better your experience here by not slowing things down to a crawl performing searches that are going to turn up hits against every post ever made. Mispelling [sic] seems to be a misspelling to me :D Okay, I confess, but that's where the wildcard should have come in though. Because this option is clearly suggested, I expected it to work. Regards, Siepel |
Sorry you got the default vb one.
Everyone complained when we switched to one w/ better word matching and searching algorithm. Which of course had its own set of problems. *shrug* |
| All times are GMT -8. The time now is 05:58 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
