Using iPad with S2ki.com
I am unable to post or reply to posts on my iPad on S2ki.com. I can read everything and all the menu functions work on the new version but ever since the upgrade I can't post or reply to posts.
Is anyone else having this issue or know of a solution to it? Thanks for any help. |
I can view, post, and even edit on iPad, I can't remember when the last time I was on a PC and got on the site.
I do not have any issues posting. I am running an ipad1 3G on iOS 4.2.1 |
I'm on 4.3.3 WiFi model
Tech tip #1:
Are you logged in? Can you check your PMs and edit your profile from your iPad? |
Yes, I'm always logged in and the messenger seems to work, it's the forums where either Safari crashes or I can't get the on-screen keyboard to type.
Thank you :-)
I can post on the iPad, but when quoting, I cannot scroll the post-text in the edit window. Then I have to try to poke the screen prior to the quotes to write something in outside the quotes.
No issues here for both iPad and iPad 2 (with the latest iOS 4.3.3).
Originally Posted by energetic
(Post 20553591)
I've tried a couple others such as Skyfire, Atomic, icabmobile and had pretty good results. |
| All times are GMT -8. The time now is 06:33 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
