South Florida Owners from South Florida
Looking for some advice
Old 02-05-2018, 06:03 PM
BBS2's Avatar
Default Looking for some advice
Hello everyone,
I would like to pick your brain for a minute on a scenario I have going on. To start off, I daily a 2000 ap1 on GC coilovers and some random eBay brand as adjustable front upper control arms. The car is lowered about 1" from OEM (previous owner had mixed match eBay coilovers slammed). The car could have been in either a small accident or hit a curb on the driver fender side, still a clean title and frame looks good. Since I had the car, there has been no issue with the car pulling to the left or right.
So a few weeks back, I was getting vibration under accelaration on the turnpike. I jacked up the car, and I noticed my rear passenger tire was really bald in the middle, still had thread on the sides (i figure too much air, I could be wrong). I took the car to get an alignment. The guy doing the alignment mentioned my driver side control arm ball joint was stripped. So I figured, perfect time to replace with OEM control arms. I didn't get new OEM ones because it was out of my price range so I got an aftermarket replacement. Now, my driver side camber is way off and the guy says there's nothing that can be done, unless I get adjustable front UCAs or take it to a chassis shop to try and straighten out whatever could be causing this.
My question to you is, 1) take it to another shop and recheck the alignment, 2) take it to a chassis shop to get it inspected/straightened out, 3) possible bent knuckle (from what I read could be a culprit) or 4) just go back to adjustable front UCAs?
Right now, my front driver side camber is at -2.9 deg and passenger is at -0.3 deg. I was planning to reach out to Andres at Kab Customs as well.
Sorry for the long read and Thanks
Old 02-07-2018, 03:20 PM
Ricky_Flowers_'s Avatar
Sounds like the car was hit up front, and something is bent. If it were my car, and not my daily driver, I'd take everything apart in the front suspension and compare each item from one to the other. Either that, or you could take it to a collision shop who could check if the frame is bent, or if the subframe is damaged. I'd absolutely fix the problem, and not go back to some adjustable control arm. I'd be willing to bet either something is wrong with the subrame, lower control arm, or knuckle. Good luck man.
Old 02-07-2018, 03:51 PM
BBS2's Avatar
Thanks Ricky. I actually took the car to get looked at today and it indeed has frame damage. Going to make a few more calls tomorrow to get some quotes. Hopefully it's not outrageously priced. I do agree that it's best to fix the problem. Seeing as I invested into this car to make it mine, makes no sense to get rid of it.
Old 04-01-2018, 05:51 AM
BBS2's Avatar
So some really good news. Although the car does reflect some damage, it wasn't something that affected the vehicle's suspension or geometry. It was a bent spindle. I finally got it repaired and realigned. Car is running better than before. Thanks again
raythechan
05-03-2018 07:59 PM
Dillon_93
07-08-2016 04:49 AM
KillerBlackbird
02-28-2012 12:16 PM
vtec4life57
08-05-2010 07:25 PM
cantsleep
16
07-22-2010 10:23 AM
Quick Reply: Looking for some advice
