Shop in Dade for chassis work?
Hi guys,
I bought upper A arm gusset plates that I need welded on. I also have some damage to one of the factory mounting points that I need fixed (I already have parts I need from a junked car).
What shop do you recommend that can do welding work, and fix structural damage in a trustworthy way, to make sure everything will line up perfect after?
To describe the damage, for the front driver’s side, the upper A-arm bolts up to two mounting points (gussets). There is a nut that is welded in place that a bolt screws into to bolt up the A arm. Some asshole alignment shop decided to break the nut loose and leave it floating in order to get an alignment, rather than discover the bent lower control arm (which I replaced eventually). With time the gusset bends. I have a new part that needs to be removed (spot welds) and used to replace the damage part. Then I want the gusset plates installed oher it to make sure its super strong.
Thanks
Thanks
Chassis master are located in miramar
(954) 985-0900
They do all sorts of work, mainly restorations on muscle cars but maybe they'll help you out.
(954) 985-0900
d1000rr
03-12-2016 01:16 PM
Car Analogy
03-25-2014 04:21 PM
tedtedted
06-26-2009 09:52 PM
undeRwhelmed
06-19-2007 03:35 AM
