Anyone Running -2 degrees camber on the front wheels ?
#21
Originally Posted by iDomN8U' timestamp='1459129887' post='23920791
[quote name='zeroptzero' timestamp='1459113548' post='23920654']
[quote name='A. Dos Santos' timestamp='1459094629' post='23920449']
[quote name='zeroptzero' timestamp='1459093579' post='23920431']
I want to get an alignment done this spring. I've been running -1.5 degrees camber front and -2 rears. I'm thinking of going up to -2 fronts (zero toe) and keeping the rears at -2 (3/16" total toe). Anyone running -2 up front, if so how has it worked for you ?.
[/quote]
Hard to say if camber will help... You could heat up the fender liner (heat gun) and with some thick gloves form the liner out of way (Nick's little secret sauce).. Could bend the tabs as well, a combination of both might get you by
[/quote]
I don't get any rubbing of the liner itself, and I don't hear any rubbing noise, it's just the clips break apart from occasional contact.
I may just push up the taps a bit, it looks like I just need a couple mm of extra clearance, thanks for the tip
[/quote]
It doesn't sound like you need much. Incase the pin is close to the fender, you could probably shave a mm or 2 using side cutters on the tip of the clip pin
#26
Originally Posted by zeroptzero' timestamp='1459130179' post='23920795
[quote name='iDomN8U' timestamp='1459129887' post='23920791']
[/quote]
[/quote]
[/quote]
[/quote]
Thanks Dom !, yeah maybe a clip or shave of the grommet might help too. Worth a try.
#27
Remove the clip and tuck the liner behind the fender tab. Heat up the liner and bend the tab up slightly. Problem solved. If you're not planning to track the car often running 2deg camber is a waste. If you do plan to track the car. Max camber on stock adjustments should be enough depending on the tire you are running and how aggressive you are at the track.
#28
#29
#30
