CEL Misfire problem, worth to do a fuel injector cleaning service?
#21
#22
#23
I'll make an arrangement for leak down test with a shop close to my work place. Will update any progress when that's done.
Thanks to all your advice!
#25
Could be something as simple as a bad valve adjustment
#26
Originally Posted by C63AMG' timestamp='1433164665' post='23631848
[quote name='starchland' timestamp='1433139079' post='23631609']
Personally I like to check it hot since we are concerned with running parameters and what state will most likely show an error , to each his own
[/quote]
Not when you're just checking for a difference in compression between cylinders. Otherwise, yes, operating temp is ideal (ie in the case where they all seem abnormally low).
Compression % difference is based on a control. As long as you do them all within a cretin timeline hot/cold doesn't matter (ie don't check one cold then the other 3 hot etc).
#28
What is a VC by the way?
Before taking it to a shop, I plan to do another dry/wet compression test on cylinder 1. So that at least I can have some clue of the appromix leak... Valve or rings.
If the wet test has higher PSI number then it means leak from the rings, isn't it?
#30
This was one of my Cyl 1 ex valves after 190k. Too much pitting to machine. Cold compression was mid 220psi on Cyl 2-4 and high 180psi on Cyl 1.
Block, slight scoring in Cyl 1 but within Honda's spec.
