hard shifting at high rpm - S2KI Honda S2000 Forums
Notices
Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Old 10-10-2016, 10:41 PM
Default hard shifting at high rpm
Hi,
very difficult to get into 3rd, 4th, or 5th gear when driving hard (6K+ rpm) - whether upshifting or downshifting...i need to apply a lot of pressure on the gearbox and it feels quite notchy. I've already had the clutch and transmission fluid replaced. Clutch does not seem to slip nor leak, shifting feels okay under normal city driving.
FWIW, I'm running oem clutch and pressure plate on a 6 psi (stock boost) SC. 102K km 2004.
Any ideas? So far, the possible culprits are:
- throwing bearing
- pressure plate
- master/slave cylinder
- transmission
unowned is offline
Old 10-10-2016, 10:47 PM
Also, I should add that I did a bunch of trackdays this year and the gearbox had felt fine until my last trackday where it became so difficult to shift that I ended up spending the remainder of my day in 3rd gear. As if the shifting characteristic changed overnight.
unowned is offline
Old 10-11-2016, 03:42 AM
how does it shift at idle?
Any leaks from the master?
starchland is offline
Old 10-15-2016, 07:41 PM
shifts fine at idle and at 'normal' city driving, no leaking from the master and fluid was just changed.
I've noticed that if i deliberately slow down my shifting, the 'locking out' is less pronounced. Are my synchros possibly failing? What are the symptoms of failing synchros? failing throwout bearing?
unowned is offline
Old 10-16-2016, 05:33 AM
zeroptzero's Avatar
I don't think synchros go bad in such dramatic/quick fashion it would have been a more gradual process, and it would be bad in all driving conditions IMO. I think it is mechanical in nature where one part is faulty. How is the clearance on your clutch rod under dash ? Maybe bleed the clutch line as a precaution.
zeroptzero is offline
Old 10-08-2018, 08:47 PM
bumping for ideas on cause. I was about to drop a load of money on a new clutch, but there's little indication of slip so im not sure if that is the culprit. If Im driving at a tepid pace, car shifts fine in all gears, but once i start flooring, there's a very noticeable shifting delay, or at least i need to let off the throttle a bit upshift. Ive had fluids changed several times. The symptoms started becoming more pronounced after my series of trackdays last summer
unowned is offline
Old 10-08-2018, 11:29 PM
Woah...no solution after 2 years?!?!
i’d seriously look at changing your slave cylinder
clubhopper is offline
Old 10-09-2018, 05:13 AM
I had a similar problem with a countersunk knob. Seemed I was shifting too fast or maybe the synchros weren't ready. The other time I had shifting issues, I got pissed and jammed it into gear. Broken spring holder in the clutch. You should be rev matching the best you can, sounds like you are powershifting by your post. Have you removed your CDV?
cntchds
10-28-2015 06:17 AM
hshiznit
11-12-2010 12:06 AM
hangcool
07-17-2010 10:09 PM
StinkyTofu
10-23-2009 02:33 AM
AZS2000
10-12-2004 02:29 PM
Quick Reply: hard shifting at high rpm
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
