Just installed Buddy Club N+ Coilovers - Need Alignment Advice
Hey guys So I just finished installing The buddy club N+ Coilovers. A quick first impression - at 1 click from the softest setting, they are more comfortable over bumps than stock, and hugs the road and corners excellently. There is about a 1 finger gap all around. Definitely an upgrade. They look and feel amazing.
I need an alignment now. So wanted to ask advice on the type of alignment I should be getting. There are some shops in Brampton that offer 4 wheel laser alignments for $60, and lowered cars for $80 - but they are not performance oriented shops. What sort of pricing should I expect from a performance oriented shop? And is it nessecary to make sure I take it to the right place? If so any recommendations? Is there anything specific I should ask to align given my setup?
Cheers!
Cheers!
Just do some research on different alignment specs and see what is best suited for you. If your just street driving, getting a track spec alignment is a waste and you'll just kill tires. A few guys here have used the UK alignment specs for street driving.
A four wheel laser alignment is what you want, make sure they can accept lowered cars as you noted. That pricing you listed is pretty good. You should go into the shop and give them your specs, and get a printout of the results. Otherwise they will just set it up according to oem recommendations in their system and you can do better than that.
If you are planning to track the car you may want to find a shop with race suspension experience. Otherwise most shops with good equipment can do a decent job as long as you tell them what specs you want.
I've been running the following specs with decent results: -1.5 degs camber front wheels, max caster front wheels, zero toe front wheels. -2 degs camber rear wheels , 3/16ths inch total rear toe-in (3/32" per side). Steering wheel straight. Tire wear has been perfect. It's pretty close to UK specs, I've got an Ap1, not sure what year your S2000 is.
I'm bringing mine here tomorrow based on a reco from here. http://www.apexmotoring.com/alignment.php?a=3
Going with UK specs with less rear toe for the AP2. Getting a corner balance as well for shits and giggles.
sold my MINT BuddyClub N+ 3 weeks ago, had them for 15K, good bang for buck street use.
Now on AP1 suspension with AP2 V3's.
If doing an alignment, also this is good time to check your subframe bolts. Make sure they're not loose, be safe and have fun this year.
Check Your Subframe Bolts, good read.
