Lowering springs questions
Couple months ago I got a set of Neuspeed 55.20.65 lowering springs came with pretty new OEM shocks. Today I tried to install these things and replace the old OEM springs/shocks. But when I compare these two I don't see any difference in heights? Even after I installed and measured 3 fingers gap in there lol..
Neuspeed 55.20.65 should make car lower 1.25 inches as per the spec. Is it because the nut in the middle of the top hat need to be tightened a bit but how to make sure left/right the same height? Just use the spring compressor to reach it's maximum tension? I know it's kind of dumb questions but I know quite little about suspensions... Thanks for all kinds of comments! https://c2.staticflickr.com/2/1659/2...df6703f4_b.jpg https://c2.staticflickr.com/2/1566/2...717ec155_b.jpg |
I'm guessing you didn't preload the suspension when putting everything back together
Originally Posted by afzan
(Post 23913515)
Most lowering springs, especially when brand new will take time to settle. You may not see the full drop for a week or two. Lowering springs are usually stiffer so they take some time to adjust.
Originally Posted by CR EH
(Post 23913541)
When I first installed my old Tein S springs, I didn't see much of drop until a few days later. Started rubbing like s*** after a few days.
You have to install it on your car first and let it sit for a few days to a week depending on the stiffness of the springs. |
Originally Posted by lpcome
(Post 23913529)
Thanks all! I have just done peload on 3 corners and torque to spec, much better now... Still have rear passenger side to do.. I feel the reinstall rear suspension by my own is really hard, maybe I will use the car equipped Z jack to align the bolts?
Originally Posted by myflys2k
(Post 23913633)
Originally Posted by lpcome' timestamp='1458413414' post='23913529
[quote name='afzan' timestamp='1458412388' post='23913515']
I'm guessing you didn't preload the suspension when putting everything back together [/quote] |
